Anyone install a tailgate light bar below the tailgate?
Hcopter
KS
1996 Ranger, 2023 Maverick Lariat, Hybrid
Mine only acts as a brake light, no turn signals or backup, but it was only $14 plus $10 for the brake logic circuit to keep it from flashing with the turn signals. I tapped into the brake/turn wire on each taillight, haven't had any issues (I don't think, I'm not back there looking at it too often).
dc73pdsgt
dc73pdsgt
Tucson, AZ
None of the trailer wiring is used. The T-connector plugs into the taillight harness (no splicing).
Really? That’s intriguing, do you have a link or more info? Thanks in advance,
Dmat
Baton Rouge
MAVERICK
Was looking for the coloring of the tail light wires and found this thread. What im at a loss for though is my colors dont match the colors listed in the diagrams. well not all of them. I'm naming them as wire-strip.
Like it looks like I have violet-white and gray-yellow on one row. the next row. has Green-White, Violet-Dark Purple, and Green-Brown.
I've been able to test that the second row is turn/brake, running, reverse but ive got no clue what the top ones should be aside from a ground.
Any ideas.
edit: I have a lariat so this is a 6 pin connector. are the XL and XLT also the 6 pin?
Hcopter
KS
The Lariat also has an LED accent around the outer edge, that may be the extra wire(s) you're seeing.
BlueSpec1
Gene
Any ideas.
Colors are different, function should be the same.
https://www.mavericktruckclub.com/forum/threads/rear-led-light-bar-recommendations.16808/post-390640
https://www.mavericktruckclub.com/f...the-wiring-diagram-for-the-tail-lights.31676/
