anyone have a front hitch on their Maverick?
Maverickman74
Shane
Maui HI
This is a must have if you're doing any kind of off-road driving. I've discovered the winch is useful for removing dead tress and the like from the road rather than moving your vehicle.
Hopefully, for the off-road people, this can be installed without too much trouble.
As someone who owns a winch and uses it atleast every couple weeks for this or that and offroads nearly every day and used to go really hardcore offroad regularly back home in Ohio. This truck while more capable than a subaru and others. Im just not sure this is the type of truck that if you cet stuck in it that you want to go forward. Where the trail may be worse and worse. If there is a log or something in the way. Turn around and winch it out of the way from the rear hitch. Or hook it up to your front hooks and pull against a tree behind you. Alot of times getting stuck is just a matter of the wrong line. Instead of pulling yourself through the worst of it. Pull yourself backwards and take a different line. Or use your saw to chop some wood to fill holes or go back and stack rocks to make it through. However we are pushing the capabilities of what you should be putting a unibody with about 6" of suspension travel through. I will take mine offroad for sure. But I wont be using like I use my solid axle comanche.
Ford Maverick anyone have a  front hitch on their Maverick? 0308201357
Ford Maverick anyone have a  front hitch on their Maverick? 0303211707
Ford Maverick anyone have a  front hitch on their Maverick? 0303211722
Ford Maverick anyone have a  front hitch on their Maverick? 0306201359
Dad
Great advice all around. I really love the Jeep pickup. I see Jeep re-designed and re-issued the pick-up with the Gladiator badge. Let's face it, the Maverick is not really designed for hard core off-road. It lacks a locking rear differential and the independent rear axles lack the same articulation as a solid axle meaning less contact with the road if you get twisted. I believe the AWD FX-4 was designed more for those who have to deal with snow and mud on regular to moderately rough roads.
Comet71
Comet 71
IL
1971 Ford Mercury Comet
Ford Maverick anyone have a  front hitch on their Maverick? 81W1ZKAspqL._AC_UY218_
WARN 101575 Handheld Portable Drill Winch with 40 Foot Synthetic Rope: 750 lb Pulling Capacity , Gray
4.7 out of 5 stars 951
$260.82$260.82 $274.99$274.99
FREE Delivery Thu, Feb 3
Only 5 left in stock - order soon.
More Buying Choices
$258.48(2 new offers)
Ford Maverick anyone have a  front hitch on their Maverick? 61p4t4m-g6L._AC_UY218_
SuperHandy Electric Portable Winch Hoist Crane Lift Brushless Motor Li-Ion Battery Powered 1000Lbs/455Kgs Max Weight 20' Feet/6m Steel Braided Cable w/Locking Knob for atv truck boat trailer
$399.99$399.99
FREE Delivery Fri, Feb 4
Only 12 left in stock - order soon.
this is the other option something portable.
And yes, The Maverick is not capable of Extreme Off-Road. Still If I fall into a ditch on a snowy day a winch will be very helpful.
Dad
More Buying Choices
$399.99$399.99
Absolutely! This looks like a perfect solution as long as you have the rescue hooks. I'm sure there are many people who will find your suggestion a terrific and reasonable option. Great post!
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I just shiver at the thought of someone doing that sort of thing with a Maverick.
  • Like
Reactions: Dad
Maverickman74
Shane
Maui HI
More Buying Choices
$399.99$399.99
I wouldnt recommend those two pullers for vehicle recovery. They are more for material handling and atv recovery. If you have the FX4 with the two hooks you would do better to keep a come-a-long ratcheting puller and a couple straps or a synthetic winch line extension. Some larger come-a-longs are rated for 8000lb which is powerful enough to pull a stuck vehicle out(which generally requires 1.5 times the vehicle weight).
You could reasonably setup a recovery kit with 2-3 straps, 2-3 shackles, and a come-a-long for about $150 and it will all fit under the back seat.
Come alongs will only pull you about 8 feet at a time. If your recovery is longer than that, you need extra straps or logs or bricks to hold the vehicle after your 1st pull to re-adjust your pull line and set up for a 2nd pull and so on.
While a winch would be cool on this truck and I'm sure someone will install one, maybe me after I pay it off, but I dont really think its necessary for what this truck will get people into.
Maverickman74
Shane
Maui HI
Just because we can do things doesnt mean we should but someone probably will lol.
Dad
Lots of experienced information in your post. Thanks. With a rating of only 750lb pull, I wouldn't think most experienced off-roaders would use these as vehicle recovery ... only for clearing the road of hazards. I think your suggestion of a come-a-long is good advice. I'm not planning on using my hybrid off road, but I am interested in learning as much as possible about the Maverick in all its configurations. Truly a remarkable vehicle.
Maverickman74
Shane
Maui HI
If you have hitch o the back its still not the worst idea to have a come along and a couple straps. Could get you out of a situation in a grass parking lot or in snowy weather. Also works great for securing a heavy load.
  • Like
Reactions: Dad
Michaelkov
Michael
Atlanta, GA
2021 BMW X1, 2018 Toyota Rav4, 2022 Ford Maverick
Looking at putting a front hitch one, we have always had front hitches on our vans and trucks. Has anyone already did this? if so, what did type did you buy and how did you put it on there. any issues?
You might be able to use a FITS adapter...
Ford Maverick anyone have a  front hitch on their Maverick? 2022_ford_maverick_frontvi
SaskCracker
Graham
Flin Flon, MB
Anyone know what kind of rating this little bracket has?
Seems beefy enough to mount a lighter weight hitch - like a class 1 or 2 … enough for just a winch.
(2022 Maverick XLT Ecoboost)
Included wider and zoomed-in shot.
Ford Maverick anyone have a  front hitch on their Maverick? imag
Mavster Mechanic
Hybrid
Yes.
That's for holding aftermarket fog lamps.
Hope that helps!
notfast
Los Angeles CA
I'm gonna guess that it isn't a whole lot. Those holes are used to support the FX4 tow hooks, but the tow hooks themselves thread into bungs that are welded into the unibody rails.
I'd use the Demco base plate as a base for fabricating a front hitch, or even just buying one and modifying it. But at $800+ for the base plate, I think that money would be better spent on other things than a cobbled-together tow hook or hitch receiver setup.
https://www.mavericktruckclub.com/forum/threads/demco-base-plate-for-2025-maverick-xlt.64288/
https://cdn.demco-products.com/documents/Manuals/TP29366.pdf
Dad
I'm no engineer, but I'm assuming the tow hook attachment is designed more for forward load rather than a downward load that a heavy winch would create. I don't have tow hooks on my hybrid, so I'm speaking off the cuff.
