Anybody run the maverick on strictly premium fuel?
Jalopy Technology
Rick
Central Wisconsin
'25 Maverick, '04 LeSabre, '99 Grand Cherokee, '88 F350 crew cab, '65 Dodge Coro
My EB gets about 2 mpg bump when I use 91 octane on the highway. And a significant increase in performance,too.
I never thought I would say that...
dalola
Retired
SE Ohio 🇺🇸
It's interesting data provided by a member, but it's hardly conclusive, and that's the only point I'm expressing.
Do we have all of the data points showing the same conditions to go along with the times? And what data is included? Are the conditions so close that we can assume the variance in results is due solely to differences in octane?
Hot air is fine as long as it's controlled to be the same for each run.
For timed runs, people under-estimate the effects of the "variables", the biggest being the driver. Being a consistent driver for a drag race is very difficult, as anyone who's raced can attest to. 5 or 6 tenths look big on paper, it's a blink of an eye for a driver. I've never put my Mav on a track, but I've hobby raced a lot of other cars, and consistency is difficult with track conditions, let alone out on a country road or parking lot. Just fooling around, I'm getting about a half second difference to 60 between 87 &93 with my EB. A dyno would be a much better tool to show actual gains/losses as it relates to fuel. But I'm sure the Ford spec's would be accurate, if not slightly understated, as many of the EB's are.
dochawk
doc
Las Vegas
They only wanted You filling up Gas Cans not driving your car up to the pumps and filling it up. :)
So you put a row of gas cans in the trunk, all of which drain into the tank . . .
I have only run 87 in my hybrid
the hybrid, from all the information we have, has no use for the extra. This is really about the ecoboost.
Are the Teslas aware that you're trying to race? 😂
more importantly, is it aware that you're trying to feed it gas?
:crackup:
Back in college I was in a '72 Impala 400. One night out with my friends, a couple of little riceburners were racing their engines at one another, waiting for the light.
As they raced on the green light, I casually passed them on a modest throttle (for that 400) .
[you should have seen their faces as they realized what was happening!]
I wonder which one tastes better, 87 or 91 ? Let you all know tomorrow. 🤮🤣
ask the Tesla?
ice445
Ryan
Utah
24 XLT Tremor
One thing I'm curious about is how long the octane learning takes. Some people say it's after you fill up, some say it takes a whole tank. I personally can't imagine it would move that fast, otherwise the whole point of the octane modifier would be kind of moot. Knock events lower the modifier, so I imagine time without them is what increases it. But I wonder if that time value is variable as well, especially if your modifier was in the toilet. Stuff a tuner would know, I'm sure. I'm used to platforms where it either knocks or it doesn't, and timing is pulled or added accordingly in real time. Not that the Ecoboost doesn't do that, but the modifier in theory prevents it from always riding the edge of knock. I'm far from any sort of expert, however.
Personally I don't think you can really see the difference without a dyno. I'm sure torque management will delete any extra low end you can make anyway in a 0-60 run, especially with traction control on. All that torque steer lmao
Tbone289
MO
You can monitor or data log the Octane Adjust Ratio Learned along with timing advance and knock events with an OBD-II interface and you'll see that it begins to adjust within a few miles of filling up. It does not take anywhere near a full tank, and anyone stating that it does doesn't understand how OAR operates.
One thing to keep in mind of course is that lower octane fuel left in the tank at fill-up will "dilute" the octane of the gas you're filling up with. If you're switching from 87 to 93, and have a couple of gallons left in the tank at fill-up, the full tank won't be at 93 octane. Due to this, it would take a few fill-ups to bring octane up to maximum.
There are lots of great discussions on the web about Octane Adjust Ratio:
https://cobbtuning.atlassian.net/wiki/spaces/PRS/pages/30900459/Tech+Bulletin+-+Octane+Adjust+Ratio
https://www.mustang6g.com/forums/th...nd-ignition-correction-on-the-ecoboost.19738/
https://dizzytuning.com/blogs/technical-documents/what-is-oar
dalola
Retired
SE Ohio 🇺🇸
As Tbone explained well, all the various sensors that relate to knock, timing, boost, etc...cycle many times per second. There is no "waiting around".... Adjustments are made instantaneous to conditions.
And if you focus on Being consistent, you can absolutely "see" a difference, even with just a stop watch, but certainly a dyno would be the better tool. The 2.0 EB is not exactly a torque monster, and the AWD system always splits power delivery on initial acceleration. You can turn TC off, and go WOT with very little tired spin. FWD, not so much.
MaverickNoticer
Dan
Smyrna, DE
Maverick '24 XLT
I run my 22 non hybrid on 87 reg fuel. Hearing people get more horsepower and better for engine to run on high test. Any opinions?
My understanding is this would be most effective at high altitude or under high temperature.
Octane is anti knock rating and in situations that could cause pre-mature combustion, a higher octane will be less likely to combust early and cause knock.
ice445
Ryan
Utah
24 XLT Tremor
Makes sense, thanks for that. So it will take at least a little while to max out the modifier for the best performance?
dochawk
doc
Las Vegas
I know the argument that you are throwing money away using higher octane gas than what it says in the manual
ask the Tesla?
dochawk
doc
Las Vegas
older systems like Northstar listen for pre-knock, and immediately cut back on timing. This would happen as you accelerated; it didn't take a few seconds.
I can't imagine that thirty years later they've been replaced with something substantially slower.
It's conceivable, though, that it advances boost more conservatively (slowly) than it retards timing. For that matter, it might advance spark more slowly than it retards it.
Also, it's been reported that the most recent versions of the ecoboost have doubled the prior number of sensors, to the point that they can adjust for individual cylinders!
ice445
Ryan
Utah
24 XLT Tremor
With the "waiting around" thing, I was talking about the adjustment modifier, not the knock response itself. As someone else said, it takes a few tanks to get a "pure" 91 tank and therefore the highest modifier value.
Knock octane modifier is basically a learned value so the ECU knows about where to start timing as far as I understand it, so it should move slower than the normal knock response logic.
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
2025 owners manual says 87 octane fine but:
“For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer.”
Only 2 tanks of 89 octane into my new EcoBoost so far. Going to use 91 during the Spring/Summer/Fall out here in the Arizona Desert.
I drive maybe 3000 miles per year, so added fuel cost will be relatively low.
Not expecting more horsepower or better MPGs - just want to avoid any potentially expensive engine knocking. My Lobo will stay in Sport mode as I’m retired yay.
3000/Year? I do that in a month and a half! 😅
MaverickX2
McCormick, SC
2025 Ford Maverick
I have only run 87 in my hybrid and put on 5,500 miles on it thus far and still get over 40 mpg on a consistent basis. Low and slow like my BBQ. I bought it to save money on gas as we drive a lot being retired.
lol No this is what I use to race .
Ford Maverick Anybody run the maverick on strictly premium fuel? IMG_0525
Ford Maverick Anybody run the maverick on strictly premium fuel? IMG_0531
Cherokee
Marty
Been running real gas,
93 octane NON ETHANOL getting 28-31 mpg’s .
My ethanol free pump broke down, been back on 93 octane premium ethanol.
After a near empty fill up my
Mpg’s are now 27-29
Just sayin ~
