Any recommendations for Maverick rims???
Barracuda340
Abilene Tx
but its ultimately not.
casey in point:
or
whats the point? the point is - never trust a man with no shirt
Who is Casey, and why are they on point? Is Casey a bird dog? My friend trains bird dogs. But I digress. You need to ask that fat guy with no shirt on, or the fat chick on the billboard if either one of them are wearing some Air Jordans 🤣🤣🤣🤣🤣🤣
stoptothink
Utah
'17 VW jetta
casey in point:
or
I have no idea what just happened, but it certainly wasn't an argument against the fact that people like different things (including wheels/rims).
Barracuda340
Abilene Tx
Hey, I agree. I however felt that it was bad decorum for another member to dog out other peoples choices, when the OP simply wanted ideas. The OP did not specify a budget. With this in mind I gave them the bolt pattern, mentioned OEM take offs, and that the aftermarket has an insane amount of wheels in this bolt pattern. To find something they like and go for it.
Barracuda340
Abilene Tx
Sort of agree here. Probably not worth the money unless you're saving more than couple of pounds per wheel/tire. I also think the stock steelies look great and would look even better with some clean center caps.
Chrome acorn lug nuts and some stainless steel trim rings would make the steelies look better.
mspmms
'MERICA šŸ˜Ž A gulf is named after it.
2022 XL Ford Maverick šŸ‡ŗšŸ‡ø
Ford Maverick Any recommendations for Maverick rims??? download - 2022-06-18T070747.648
Mavericksport
Peter
Connecticut
This is not an uncommon. Bolt pattern. Plenty of options out there for the 5x108mm pattern. That's also a GM pattern. My 2008 Chevy HHR uses it, and a bunch of GM products from that timeframe used that same pattern as well. This just means there is a lot of aftermarket support for that bolt pattern. Heres a set of 18x8 Circuit performance rims I bought for my XLT which I should have a vin# for this month. These are spec for Focus RS MK4 so I know they will fit. I added ebay ford center cap medallions. I think these will look good against iconic silver and with an H&R spring kit to drop it. As far as stock stuff though, plenty of ford and lincoln vehicles with interesting wheels in this size. I believe range rovers use a 5x108 as well.
This 5x108 bolt pattern sucks. Even the guy at the tire shop said that. I'm looking at bigger rims, and there is maybe 5 choices , but not nice enough to buy yet. Still looking. If it was the 5x114.3 there is so many more choices, not sure why ford did this??
Barracuda340
Abilene Tx
I respectfully disagree, theres plenty of different style wheels in 5x108mm. The style you want may not be available in that bolt pattern, but that doesnt mean theres only maybe 5 choices. Dont go by what the "tire shop guy" says. Use the googles. I found so many 5x108mm fwd offset wheels that it was hard to choose what I wanted. Not sure what you are looking for, but theres lots of "tuner" style, to "offroad" style rims in this pattern, and in a 35mm offset. I have seen 17" 18" 19" 20" diameter rims in this pattern.
Your tire shop guy probably gave you that answer because he isnt interested in what you can probably get on your own and only interested in selling you what he probably has at his shop, which may be that small selection your talking about.
Go to tirerack.Com and search 5x108mm wheels and theres a bunch. That's not all the rims you can get, theres lots of other companies. Mine are from circuit performance. Check there too. Lots of good looking wheels in the 5x108 on their site too.
Mavericksport
Peter
Connecticut
I respectfully disagree, theres plenty of different style wheels in 5x108mm. The style you want may not be available in that bolt pattern, but that doesnt mean theres only maybe 5 choices. Dont go by what the "tire shop guy" says. Use the googles. I found so many 5x108mm fwd offset wheels that it was hard to choose what I wanted. Not sure what you are looking for, but theres lots of "tuner" style, to "offroad" style rims in this pattern, and in a 35mm offset. I have seen 17" 18" 19" 20" diameter rims in this pattern. It's the same pattern as GM FWD cars like the HHR, Saturn VUE, pontiac G4 and G6, Cobalt SS, Chevy Malibu, and others.
I'm looking at 21" or 22" . The tire shop owner doesn't care , because it's a little tire shop. So they have nothing in stock. Also he said it's a new vehicle, so alot of rim shops can't say yes they will fit. I called 2 other places, and there website say they not fit may maverick, but they will sell them to me, after I signed a paper , because there is no fitment guaranty they will fit. Also my lariat came with 18" , in my opinion it would be silly to buy 1" bigger or smaller.
  • Like
Reactions: HPR
Mavericksport
Peter
Connecticut
I'm looking at 21" or 22" . The tire shop owner doesn't care , because it's a little tire shop. So they have nothing in stock. Also he said it's a new vehicle, so alot of rim shops can't say yes they will fit. I called 2 other places, and there website say they not fit may maverick, but they will sell them to me, after I signed a paper , because there is no fitment guaranty they will fit. Also my lariat came with 18" , in my opinion it would be silly to by 1" bigger or smaller.
Also the cars you listed are 5x110 bolt pattern.
Barracuda340
Abilene Tx
Damn, for some reason I thought they were 108mm I'm gonna have to research that to figure out why I thought this.
Barracuda340
Abilene Tx
Ok a quick google search, and heres the manufacturers that use this pattern.
Ford, Lincoln, Mercury, Dodge, Jaguar, Volvo, Land Rover, Peugeot, Oldsmobile, and the defunct Eagle brand. No GM products other than Oldsmobile. I will remove that from my other posts.
But 21s or 22s on gum band tires, arent you looking for an odd duck. I have seen people post 20s and 21s off some land rover products on here, and I have seen guys getting stuff custom made to these sizes
Treadz
Michael
Surprise, AZ
24 Maverick XL AWD
We have a few styles for the Maverick and Bronco Sports.
racelinewheels.com
I had multiple styles on my Bronco Sport. And added these on my Maverick, we have three new styles coming out in the coming months.
Ford Maverick Any recommendations for Maverick rims??? 7038E666-A68A-4CB5-AE56-6789EA76B558
Ford Maverick Any recommendations for Maverick rims??? AC3F5F02-3609-420F-88DE-7C5ED8ED79B2
catinthebathtub
haas
houston
66 GT 350, 60 VW, 34 pickup and porsches....
just for fun you guys can look at www.demontweeks.com
prices start crazy low but i got a shipping quote on a unique set and it was crazy high. :rolleyes:
