Aftermarket Blind spot sensor
Xbluecat
Bruce
Pensacola
2024 Ford Maverick
I’m getting neck surgery and my range of motion is gone. I almost pulled in front of someone yesterday. Is there any advice on aftermarket blind spot sensor purchase or installation? I will be paying to have it installed. I have a 2024 Maverick XLT with a backup camera. Thank you!
Move your side mirrors out more? Should NOT be able to see your own vehicle in them unless you lean over to the driver door or center of the vehicle.
👍👍👍👍👍👍👍👍👍Yes yes
I use the SAE recommend mirror positions.
Unless backing up.
I don't need to see the side of my car. If something is close enough touch my door handle it's too late.
ZABSMAV
Utah
2023 Maverick Lariat Hybrid
Our 2023 Lariat hybrid alerts in the side mirrors if someone's in the blind spot.
ZABSMAV
Utah
I hate to be blunt, but if you are not able to properly turn your neck to observe traffic and pull out into the road safely, it might be better to have someone do the driving until you are recovered. I am sure you would run into some very serious liability issues if you caused an accident and it was determined that your range of motion made your driving unsafe.
ceballs
SE Pennsylvania
'24 Maverick XL AWD 4KTow 360 & Hyundai Ioniq 5
I have a similar problem. I use Grote 2” stick on blind spot mirrors on all my vehicles, they work. I used to drive dump truck and similar so blind spot mirrors were part of my everyday life.
Ford Maverick Aftermarket Blind spot sensor IMG_3534
CTYankee
Central MA
2022 Maverick XLT
This shouldn't be about just blind spot monitoring. Depending on how limited your range of motion is (or will be), it's also about intersection angles and whether or not you can adequately check for approaching traffic before entering the intersection.
You may need something that can provide a broad field of vision at distance and at a resolution that let's you see clearly what's approaching at any angle past which you can turn your head. There are plenty of 360-degree systems out there but none that function at distance that I'm aware.
My advice is to seek out a company that specializes in outfitting cars for the disabled. They may be aware of products that will cover all those bases.
jcgaskil
Allen, Texas
Maverick XLT FX4 (Alto Blue)
Did you end up selecting and installing an aftermarket BLIS? I am consider the Brandmotion system but I'm doing researching options. I've never installed one and curious if anyone has had success with them.
https://www.brandmotion.com/product/radar-blindspot-system-with-cross-traffic-detection/
fuego
FL
All Honda one Ford
jcgaskil
Allen, Texas
I haven't pulled the trigger yet. I had to take a pause after upgrading the stereo. I have a pesky parasitic draw I need to resolve before adding one but it is still on my Christmas list.
