Adding sound deadening. Soon.
AndrewSKY117
Andrew
Olympia, WA
'22 Outback Limited
I'm certainly excited about doing some of this. Looking forward to seeing some results. I'm thinking of putting some under the hood as well if that seems worth it.
Area51BS
Ron
Opinions. Thinking of removing the amplifier mounting bracket from back wall. It vibrates like a sob tapping on it. Not going to drill spot welds as they are visible bedside.
Ford Maverick Adding sound deadening. Soon. FD8900D7-464A-4AAA-B4C9-C93A05487C57
LC48
Johnson County Texas
Well, still some more runs to do but my initial tests with the foam behind the backseat made no discernible difference to my ear. Have some more commutes to do and will use my sound meter application but not hopeful, but it was free and easy...
My next thought is doors. My reasoning being the floor, while I am sure is a source, is significantly heavier gage than the door skins. Next behind that I think would be the firewall / forward footwells.
Thoughts?
mamboman777
Josh
NRH, TX
Having owned and driven this MAV for a month I can hear the most noise(road) from the rear. It’s not bad but definitely the loudest area of the truck.
That makes sense. I guess I am most concerned about engine drone. I've heard some of the hybrid videos especially when towing and it's a little bit much.
Area51BS
Ron
This is the spectrum analyzer at 55mph. No wind tonight. Fan speed on 2. No acceleration and no other cars near me. A normal/not smooth but pothole free 4 lane road I frequently use. Disregard peak as that was during acceleration.
Ford Maverick Adding sound deadening. Soon. 1D062EB6-2C27-489E-B785-6DDE77B9534C
KenC
First
Earth.
Truck.
My Nephew is a mechanic for Mercedes he seems to think that there is a chance a warranty can be voided simply by doing something as simple as adding sound deadening. My neighbor with her Kia says that if she doesn’t adhere to Kia’s timely maintenance schedule that her warranty can be voided. Thoughts?
Area51BS
Ron
Never had an issue with any vehicle warranty. Who puts the same tires on as factory? Don’t have to use Motorcraft oil. Sound deadening might cause a warranty issue for rust through warranty if it rusted under it that quickly. Some service advisor just scared your neighbor. Service intervals are recommended based in many things.
KenC
First
Earth.
Truck.
Ok cool. Thx for your insight.
Cool. thx
Area51BS
Ron
Progress report. Well worth it. Did most of the back wall. Still going to do under back seat. Simple to disassemble.
1. Raise seat bottom and unsnap threshold trim.
2. Remove trim around seatbelt near floor by unsnapping pulling up towards you and sliding it up. Small track it slides into.
3. Lower seat bottom and lower seat back. Unsnap back panel trim. Lay it on seat back. No need to remove seatbelt.
4. remove the long pillar trim that runs up to speaker grill starting at bottom of trim. Starting up near speaker grill is much harder. There is not much to deaden behind this trim but there is some stamped holes and a little flat surface to cover.
NOTE. No reason to remove speaker grill. Nothing you can effectively cover. No surface area and lots of structure behind speaker. If you must. Remove front bottom 7mm fastener. Bottom back is magnetic against pillar. The top clips of grill require you to push grill towards roof before pulling out. The clip hole is cross shaped and clip does not pull out until you push upwards and it centers with cross. Don’t waste time here though.
Additional notes. Nowhere flat so a roller is useless. Use a smooth round object. Backseat removal is not necessary to place deadening under it as it is very accessible from back and under seat. The storage boxes just unsnap after removing step 1 threshold cover.
Working on spectrum analyzer pictures to overlay them. But they don’t seem right. Pictures below are in progress pics.
Impressive amount of metal structure back there, in upper pillar and under seat.
Ford Maverick Adding sound deadening. Soon. 1078D020-81EF-44D8-8AE2-661283228FD7
Ford Maverick Adding sound deadening. Soon. 03760DC3-8917-4578-BC60-8190648A1E51
Nw_adventure
Salt Lake city
Bed without a liner or undercarriage noise ?
felsf50
Scott
NEPA
What is that big actuator to the right of the bracket?
