Adding Navigation to the Maverick Lariat
jsus
2022 Ford Escape Hybrid AWD
Just curious if you can use voice to change the temperature? I have the Lariat Lux and the current OEM does not seem to support that (tried it through AA so not sure if the OEM Sync system interface would make it work). Not something overly useful but fun to play with.
Glad to know this can work though!
If it's enabled on-screen, Sync voice commands should be able to do it as well. Though if you're using Android Auto or CarPlay, it's a little trickier to use Sync voice commands (defaults to Google Assistant or Siri).
MaineAssassin
Sheldon
Maine
F-450, Flex, Maverick
Thanks I wondered if the problem was having google be the interface or something else. Be interesting to hear from someone who has android auto running and uses the voice to see if it works that way. Currently it says "Sorry, I can't do that on this vehicle"
TheShark
TheShark
I never thought of using voice commands, I'll have to give it a try.
TheShark
TheShark
yeah, same here i contacted him as well. said the same thing to me, i was just looking at the 2nd one Shark listed and i am looking at his feedback now. 203 positive 0 negative feedback in the last 12 months. seems okay to me.
but i think i will wait until after i get this recall thing taken care of before ordering.
Dokus223 was my second choice, I had contacted them and was impressed by their quick response and answered my questions, plus the great feedback. Unfortunately the guy I bought mine from doesn't seem to have the Sync 3 Gen 4, I might have gotten the last one he had, at least for now.
A few of you guys should do a group buy, the more you buy the cheaper the price. :)
crashdumie
unknown
Ocala. FL
2023 Ford Maverick Lariat
im sure the discount is for the combined shipping. i might try to hit up a local junk yard to see if they have any 2020 or newer escapes might be able to pull one out of there. then just need to figure out how to program the VIN.
TheShark
TheShark
If you have Forscan or know someone that does you can program the VIN yourself.
crashdumie
unknown
Ocala. FL
i just got forscan the other day. i haven't played around with it much yet. just added speed limit signs. my last car had Sync 3 with Nav and the signs appeared on the dash, i got used to looking there for the limits.
but i am guessing it is just going into the APIM module and changing the VIN
Gullzway
OK
1968 Ford Mustang Fastback
Sadly, I don't think you can use Sync 3 Voice Commands with Android Auto or Carplay in use. Which means you would have to unplug your phone to do this? Not very convenient .
"Note: When Apple CarPlay or Android Auto is active, SYNC 3 Voice Recognition is disabled and voice commands will not work."
How do I use SYNC 3 voice commands? (ford.com)
jsus
Yep, native Sync voice commands and navigation are disabled with Android Auto/CarPlay connected which would require you to disconnect your Android device/iPhone to use said features. Like I said, a bit trickier to access climate voice commands since you'd have to temporarily unplug the device. At which point you're just better off using the physical or on-screen controls...
Dallas Maverick
Dallas, USA
Volvo
I have a lariat lux and can change the temp with the voice commands. I don't know how many things it recognizes. I just push the button on the steering wheel. I can post a video later today if that would help.
MaineAssassin
Sheldon
Maine
Interesting. When using Android auto it goes through Google and doesn't work.
TheShark
TheShark
Yep, just change the vin in the APIM module. Got the traffic signs to work for me but just uses the camera, haven't the found a setting for using the signs with the camera and Nav. The signs however do appear on the center display for Nav.
crashdumie
unknown
Ocala. FL
that is why i dont care much for android auto. some of the features are nice but it all ford features and abilities are not transitions into android auto
if i remember correctly, when you activated the TSR there was an option for Camera only or Camera and Navigation. i did see some options to display navigation on the dash as well.
TheShark
TheShark
I did camera and navigation but it didn't work, still camera only. I'll have to investigate more. I'd like to find the setting to display the nav directions on the instrument cluster but I'm not sure our instrument cluster will handle that.
dalola
Retired
SE Ohio 🇺🇸
Can someone post a link to the original thread describing the replacement?
I can't seem to find it by using the search. Thanks ahead.
