ebxltfwd
B
Georgia
Ecoboost XLT Carbonized Gray
I hope this is helpful for people looking to DIY a bed mat. I purchased the horse stall mat from Tractor Supply ($47.00). Uncut, the mat is 4' x 6' x 3/4" and weighs a hefty 94lbs. I thought about using power tools to cut it, but after doing some brief Youtube research, I decided to cut it with a utility knife. It takes multiple passes with a new blade to cut through the material, but it wasn't too much work.
The main thing you need to do is cut the mat to the length of the bed, cut out the sections for the wheel wells, and then cut out to pieces for the tie downs near the front of the bed. To get a clean cut for the tie downs section, I used a forstner bit on the corners.
I also used a belt sander to break the sharp edges and round the back corners.
That's basically it. It took about a couple of hours of work to plan and make all the cuts. Here it is in the truck:
Mrdon2022maverick
Don
Georgia, USA
2022 Ford Maverick Lariat
LOOKS GREAT!!!
jc888888888
Saint Augustine Florida
Lariat eco boost, Mustang Mach E , Porsche Boxster
This is what this forum is about ! ,that is great idea and a great job. It has to be durable with 1500 lb horses walking on it NICE JOB
Maverickman74
Shane
Maui HI
Those mats make up my entire 3 car shop floor! Although I have some bigger older ones in the mix aswell. When you dont have concrete they work alright. Looks good!
Guilla
Lance
North Dakota
2022 Velocity Blue Hybrid XLT w/Lux
Wow thanks for sharing this. Another great solution.
ebxltfwd
ebxltfwd
B
Georgia
I did that with my old Ford Ranger but I used a big piece of cardboard for the template and cut it with a jig saw.
I thought about using a jigsaw or circular saw, but saw one video where someone said it didn't work well. Once I had a scrap piece, I put it through the band saw as a test and it cut pretty well, so I think the jigsaw would be a viable option.
HappyCat
Joan
XLT-4k tow-FX4-Iconic Silver
As a horse owner I knew this would be a good option. Though i am also considering wash stall mats, for better drainage. They call them anti-fatigue, but we use them in the horse wash stall for good traction.
https://www.tractorsupply.com/tsc/product/anti-fatigue-interlocking-mat?cm_vc=-10005
Here's links to the solid stall mats TSC has:
4' x 6' x 3/4 inch thick: https://www.tractorsupply.com/tsc/product/4-ft-x-6-ft-x-3-4-in-thick-rubber-stall-mat?cm_vc=-10005
3' x 4' x 1/2 inch thick: https://www.tractorsupply.com/tsc/product/utility-rubber-mat-black-4-ft-x-3-ft-x--frac12-in
Delzona
Tucson, AZ
That a seriously great idea and mat! When I read that the mat weighted 94 lbs. I couldn't believe it, then reading another post about a 1500 horse standing on it, I understood why it's so heavy.
gclmav
gary
2022Maverick,87 zuzu Trooper 2Dr. Gr.Vitara Xsport
Great job, hope I can do this if I ever get my MAV
shizelbs
Seattle
Maverick XL
Holy heck that's a heavy solution to lining the bed.
Mavhead
Jeremy
Wichita, ks
Nissan versa
I thought about this a few months ago and I think it will be a great option for my truck that I didn't order with the luxury package. Thanks for confirming that and giving me cutting ideas on what will work.
This is better than I could have imagined.
