- First Name
- Retired
- Oct 8, 2021
- SE Ohio 🇺🇸
- Website
- sunsetridgecabinhockinghills.com
- '24 Mustang Mach-E P4X, '24 Bronco Big Bend 2Dr Sasquatch, Hot Rods
- Engine
- 2.0L EcoBoost
None of that matters. If the HVAC is ON, regardless of any setting, the AC *may* cycle on & off automatically, based on in-cab humidity levels. There is no over-ride, no fix....other than shutting the HVAC OFF.Contacted Ford as suggested about and got into a chat. They gave me 3 suggestions that I'll look into. Hoping for the best.
Copied from the chat -
Here is how to disable the automatic AC and take full manual control:
- Turn Off "Auto" Mode
The most common reason the AC stays on is that the system is in Auto mode. In this mode, the truck will constantly run the AC compressor to maintain the specific temperature you have set on the digital readout (e.g., 72 ∘ ).
How to fix: Look at the climate bar at the bottom of your touchscreen. If the word "AUTO" is highlighted or has a lit indicator, tap it to turn it off.
The Result: This puts the system in "Manual" mode, allowing you to choose fan speed and vent location without the computer deciding to use the AC.
- Check the "Defrost" Vent Setting (The Most Likely Culprit)
Ford vehicles are programmed to automatically engage the AC compressor whenever the airflow is directed toward the windshield (Defrost). This is designed to dehumidify the air and prevent fogging. Even if you don't press the "AC" button, the compressor will run in the background if the defrost vents are active.
How to fix: In the climate menu on your screen, ensure the airflow is set to "Panel" (blowing at your face) or "Floor" (blowing at your feet).
The Result: Avoid any setting that includes the windshield icon (the curved window shape) if you want the AC compressor to stay completely off.
- Disable "Auto AC" in the Settings
On the 2025 Maverick, there is a specific software toggle that can trigger the AC based on the temperature difference between the cabin and your set point.
How to fix:
Tap the Climate icon at the bottom of the Sync 4 screen to open the full-screen climate menu.
Ensure the A/C button is explicitly tapped "Off" (it should not be highlighted).
Check if Recirculation is on. If you turn on Recirculation, the truck will often turn on the AC to prevent the cabin air from getting "stuffy" or humid. Keep it on "Fresh Air" (recirculation off) while your windows are open.
- Remote Start Settings (If you use it)
If you use the FordPass app or your key fob to remote start the truck, the Maverick may be cooling the cabin before you even get in.
How to fix: Go to Settings > Vehicle > Remote Start > Climate Control.
Change to: Switch from "Auto" to "Last Settings." This ensures that if you turned the AC off before you parked, it stays off when you start it back up.
Pro-Tip for Window-Down Driving:
If you want the fan to blow fresh outside air without the AC, simply:
Turn AUTO off.
Turn A/C off.
Set the vents to Panel/Floor.
Set the temperature to "LO" or a moderate temp.
