Administrator
Administrator
Staff member
MTC
Fords
bsenecal
vermont
, 2022 Ford Bronco, 1968 Ford Mustang, 2022 American Coach American Dream 39RK
Huchipapa
Houston
'01 Trooper; '04 9-3; '13 Outback; '24 Mav Lariat
Pretend I'm a mechanical simpleton (because I am..), but if I'm reading this correctly I can add a transmission cooler and the larger cooling fan to my '24 2.5 hybrid (with tow hitch) and be able to safely tow 4k?
Pierre777
Pierre
NY Long Island
Maverick XLT, Dodge Caravan and Hyundai Elantra
All those are good additions but remember the 2025 has a updated bigger and beefier EcvT transmission plus the tremor cv axles in the rear and front to allow it AWD. You need that additional torque on all 4 wheels to move the added tow weight over 2000lbs.
if I remember from 1 mph right up 13 mph the AWD is active pass that then it kicks into FWD unless it detects slippage. Also in tow/Hula mode I believe ( can someone fact check that) AWD is always active.
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
No. The 24K towing package requires all-wheel drive. The 2024 hybrid is front wheel drive only. All-wheel drive was not made available for the hybrid until 2025. So unfortunately you are still stuck with 2000 lb towing capacity with the 2022 through 2024 hybrid
Mavster Mechanic
Hybrid
Officially.
Unofficially AWD vs. FWD is the most significant change. And in my book, the only noteworthy change.
EcoBoosts need enhanced cooling to tow more. Hybrids don't.
All Hybrids have the same horsepower and the same battery power.
The eCVT final gear ratio changed a tiny bit in 2025 but that was for all hybrids. 2K and 4K. It's an insignificant change. Transmission, slightly beefier in 2025 but the 2022-24's are plenty capable.
7-pin add-on: $30
Trailer brake controller add on: $100-$200
Rear helper springs or air bags (optional) Starts at $100.
Tow "ratings" are voluntary by the manufacturer for comparison purposes and marketing purposes and are not mandated by any law.
They may choose to use them for warranty purposes, and are generally regarded as sound recommendations.
However, it is not illegal to tow more in a modified 2022 FWD hybrid provided you do meet the trailer brake and other requirements in your state.
Litmus Test:
Are vehicles with no tow rating banned from towing? (Example a 2001 Prius) What about a 1950 pickup truck with no tow rating? Not illegal in 49 states. CT is a maybe.
I am not a Ford historian and I relied on Google for this:
A 1950 F-1 had either a 6 cyl 226 CID 95 HP engine, no power steering, no power brakes.
Or an optional 8 cyl 239 CID 100 HP engine, no power steering, no power brakes.
No official tow rating from the day. Ford listed "up to" 1400 lbs cargo carrying capacity. Owners report it was capable of towing 5,000 lbs.
Darryl
Darryl
Tallahassee Florida
Officially.
7-pin add-on: $30
Litmus Test:
If the 2024 was AWD, I'd be inclined to agree that it could tow more with modifications. But officially or unofficially I think it's a bad idea to add more weight to the rear of a fwd vehicle because it DECREASES the weight on the front wheels. More weight with less traction. That seems to be a bad combination on anything other than level, dry ground. If for example pulling a boat up a wet or dirt boat ramp seems a bit of a sketchy situation with 3-4 thousand pounds with only the front tires with a lightweight vehicle such as the Maverick
OleFordGuy
EXACTLY. It’s natural common sense that many are determined to ignore
Scupking
CT
2025 Ford Maverick XLT Hybrid
Officially.
7-pin add-on: $30
Litmus Test:
The suspension is also completely different on the 25 and newer hybrids. Its now the same as the Ecoboost. By the time you modified a 22-24 hybrid you could trade and get a 25 or newer for the same price and have a more capable vehicle.
Mavster Mechanic
Hybrid
Completely different or slightly different?
A different part # does not make it "completely different".
Are Coke & Pepsi "completely different"?
How about we say 10% different.
Darryl
Darryl
Tallahassee Florida
Actually it's the AWD vs FWD suspension that is different. The actual AWD suspension is the same year to year. And the FWD suspension is the same from year to year. But 2025 is the FIRST year the hybrid was available with AWD. But whether 2022 or 2025, , hybrid or EcoBoost, the FWD has the same suspension that's inadequate for 4k towing. The only thing is that 2025 EcoBoost was only available with AWD. Wheres the hybrid was available with either FWD or AWD.
Darryl
Darryl
Tallahassee Florida
Completely different. The rear suspension of an AWD is independent. The rear suspension of the fwd is a solid axle. Nothing in common.
