Fehz
Midwest
2025 Maverick XLT
Better late than never -- I installed this system in my 2025 XLT back in March, but never got around to posting. Here are the basics of what I installed.
  • Kicker 51LX1200.5 Amp - set up as 125 watts RMS x 4 @ 4 ohm + 700 watts RMS x 1 at 1 ohm for subs
  • Kicker KSS670 components (front)
  • Kicker KSC40 2-way (rear)
  • Kicker 48CWRT104 x 2 CompRT 10" subs (shallow-mount dual 4-ohm, presented 1 ohm load to amp)
  • Kicker 46KISLOAD4 load resistor
  • Dual 10" fiberglass box from Electronics Depot - 1.3 cu ft
  • 1/0-gauge power wire
  • Additional 4 gauge ground wire for the battery
  • Complete 16-gauge speaker rewire front and rear
  • Used forscan to set flat eq
It's got a great tune setup, crystal clear audio, and tight bass. Built to look stock, but sound nothing like the rattling trash that comes stock. I couldn't give it any bass and turn it up past 10 (max 30) without the doors rattling. Sound deadening added to front doors, rear pillars, and under back seat.
I flattened the bracket used for the factory sub. Cut off the bracket for the brake controller to later be remounted. Got everything basically the same height for a larger mounting board so the amp and everything else will be nice and solid.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250316_124036
Installed Siless Max 120 mil rubber/aluminum sound deadening on ever flat surface I could in the back. Then on top of that, Siless 157 mil CCF aluminum finished as well. It's surprisingly quiet outside of the truck. Also installed around the rear pillars best I could with polyfill in there as well (not pictured).
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250316_153738
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250316_172208
Mounted 3/8" HDPE board with some oopsies on the hole locations. I needed a tiny bit more room on the left so it didn't touch.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250317_175201
1/0 Gauge power wire down the driver side barely fit, but I made it work. All speaker wire was ran down the passenger side.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250321_174647
All new 16 gauge speaker wire ran to the front to better handle the 125w rms. Overkill? Kind of. The original is all left in place should some psychopath want to take it back to stock. I used some plastic tubing and ran an all new path through grommets to protect the wiring from opening/shutting and the elements. Formed a tight seal around the tubing. Also, the same sound deadening in the front doors.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250323_210459
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250323_223537
Shaved off some tabs which allowed me to put the silk dome tweeters into the factory spot. They actually snapped in perfectly even though crutchfield said I'd need to mount them elsewhere. The crossovers had just enough wiring where I mounted them up high near the doors under the dash.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250326_213307~2
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250326_220324
Rewiring the driver side was probably the biggest challenge I ran into. For whatever reason, it took me forever to find a path out of the cabin. I used a long orange zip tie to poke around and eventually got through. You can also see the power cord going behind the foam. I had to remove the external xlt badging to make life easier also. You can see the plastic tubing and new wire running through it in a hole I poked in the grommet. Passenger side was much easier.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250328_135828
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250328_135848
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250329_211402
The amp all wired up. It's not the prettiest and I'm not particularly thrilled with it. Set the colors to match other lighting in the truck.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250405_140103
Bass boost knob discretely added. Other than this or if you lower the back seat, you'd never know anything was changed.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250406_095707
The holes in the sub box were slightly too small. Also, the entire top was fiberglass. I'm not thrilled with this box, but it had the volume I wanted. I ended up getting some mdf speaker rings and used them as backing to screw the subs into for a nice tight fit. Just needed a few modifications on the rings to get them to fit inside, and had to cut them in half and mount in two pieces to get them in there. I really wish they had made the top of this out of MDF or at least had the rings in place from the beginning. I also added Kicker's speaker grills on top to keep the seats off it (not pictured). Added some of the sound deadening and polyfill to the box.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250426_140845
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250427_090910
Power wiring under the hood. Not in the picture, but added later is another 4-gauge ground wire just to be safe. Likely overkill.
Ford Maverick Stereo Build - 2025 XLT - Full rewire and Kicker system with 2x 10-in subs IMG_20250322_093302
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
Is THAT what the floppy bracket on the rear wall is for? Factory sub? I think I'll go ahead on cut mine off.
Fehz
Fehz
Midwest
2025 Maverick XLT
Yep. Many people cut it off and mount amps in other ways. I just decided to repurpose it in my case. It just sat a little too high to allow the amp to fit. Plus, being the same height as the antenna doohickey bracket allowed me to tie in there, too. I considered covering the board in carpet and running most of the wiring behind, but there is only so much tinkering time the wife would tolerate.
Cancunbadlands
Cancun
Cancun
Clean set up 👌
zach57x
FL
2022 Maverick XLT
I am currently working through a very similar install that's been going on since the first week of December. Fronts, rears, re wiring, sound deadening, etc... If only you posted sooner it probably would've expedited my project lol. Currently having an issue with the amp I purchased and am waiting for a new one to come in and then I will do a similar post as you did. Great work!
Fehz
Fehz
Midwest
2025 Maverick XLT
If only you posted sooner....
Sorry about that. Was a fun learning experience. At the time I'd done it, no one else was rewiring the fronts/rears and the amp I used had just been released. The factory wiring likely would have worked fine, but I really wanted to be able to push the limits.
I tried using the existing door wiring harness to pass the cable through, but couldn't squeeze past everything else in there.
zach57x
FL
2022 Maverick XLT
So I did use the factory harness but had to unfortunately cut the harness boot at the white connector to the door. Once I get everything wired up I’d like to hear your take on that.
Fehz
Fehz
Midwest
2025 Maverick XLT
I think that's a pretty common thing. People will drill a hole in the white plastic connector. Well, they'll drill out to small spots to push through the positive and negative speaker wires independently. In my case, there was a spot where it was just the rubber boot that I drilled a small starter hole through, then pushed through the plastic tubing. I ended up not messing with the harness otherwise.
I would have preferred the cleaner look of going through the original harness, but I doubt anyone will ever notice the tubing. Just something I picked up from the plumbing section at a big box home improvement store.
Toddman45
Todd
St. Louis, MO
Looks good, I'm sure it sounds just as nice.👍👍
Darthie
Frank
2023 Maverick Tremor, 2016 MB AMG GTS
Sweet. May I ask what the all in cost is.
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
Super clean install. I didn't realize there was a poke-through grommet behind the driver fender badge even though I have had my badges off twice. That info will come in handy.
Fehz
Fehz
Midwest
2025 Maverick XLT
Just over $2800 with all the materials and various components. Keep in mind this was 10 months ago. I don't even want to think of what installation would have cost if I paid someone to do it.
Carlitos_92
I put the same speakers in the dash/doors/rear in my truck and had similar results. No regrets about ignoring Crutchfield’s fitment advice. 😀
I didn’t bother running new wire to the doors, but did run wire to the dash tweeters. Pretty easy since my amp is behind the glovebox.
Darthie
Frank
Amazing job
