Mas280
Yesterday I installed Rostra cruise control. I actually had my 13 year old do 90% of it as he fits better. Let me start out by saying thanks to Rostra for making the kit as its the only option. The kit is very easy to install and take about 90 minutes. I pulled the pins out of the plugs so I could use heat shrink, I did not like the idea of just putting tape over bare wires. Rostra needs to make T harness for the ignition and OBD2 plug to make it a more complete kit. Everything works good and I now have working CC on my truck. The Rostra CC switch is not as good as the factory Ford switch and I will switch over to oem CC at a later time if it becomes an option.
Ford Maverick Rostra cruise control installed on Maverick XL - my review Switch
Ford Maverick Rostra cruise control installed on Maverick XL - my review plug 1
Ford Maverick Rostra cruise control installed on Maverick XL - my review plug out
Ford Maverick Rostra cruise control installed on Maverick XL - my review plug don
Ford Maverick Rostra cruise control installed on Maverick XL - my review glue
Ford Maverick Rostra cruise control installed on Maverick XL - my review Austin working
Ford Maverick Rostra cruise control installed on Maverick XL - my review 110v 2
jtpc2021
Oklahoma
Don’t hold your breath for a Ford OEM CC option. If Ford does eventually make CC optional on the XL, it would be steering wheel mounted controls from the factory and probably not something they will offer as an accessory kit.
I could be wrong, but pretty sure aftermarket will be the option for XL owners who didn’t pay the extra $2100 for XLT.
Eagle11
Valley of the Sun
Wonder what Ford would say about this when warranty work needs to happen?
Bushpilot
Greg
Spokane, WA
Chevy Volt
Nothing, unless the cruise control caused the issue being claimed under warranty.
vezpa
EMG
IL/IN border
Too many to list.
Rostra need a stalk that had a slight "L" bend in it so it doesn't angle down so low on the left side.
Eagle11
Valley of the Sun
I get that, but on the other side, if Ford can't fix the problem they can always say the added cruise is what did it
ArizonaLouie
Lou
Phoenix AZ
VW Passat
Its my understanding that is remedied by adjusting (twisting) the angled collar on the stem included. This is the intended reason Rostra included the angled ring so that there IS adjustability on the install. It can actually be angled up.
Decayed
yes
a car
Nice CC install and all but what did you do to the bed cubby blank? Did you add your own inverter? How many watts? DETAILS MAN DETAILS!!!! 😂
Meintc
Lynette
Northern Lower TC Michigan
2022 CO Hybrid Maverick
Years ago I purchased a vehicle without cruise control and had aftermarket added along with an aftermarket rear-window defroster. Both worked very well. Congrats on your addition and congrats to your very limber son's help.
damnclose
Jeff
Greenwood, IN
2016 Dodge Caravan, 2002 Chevy Silverado 4X4
Has anyone looked into replacing the steering wheel switch from XL with XLT switch then wiring the after market Rostra cruse to the XLT switch instead of the Rostra cruise stalk that comes in the kit? I see you can get a replacement steering wheel switch from Ford just not sure how to wire it to Rostra cruise.
Depends on if Ford is encoding the switch signals whereas Rostra looks like they are using discrete wires for each control. For instance when I added cruise to my Focus the control inputs were all down a single wire, but generated different resistance values which the cruise module interpreted.
New England Aaron
aaron
Boston
Ford Maverick XL
What did you use for the bed plug? I need to do something similar on my XL
Sivart
Travis
KY
Nissan Altima
I plan to install this same CC when I get my XL. Rostra has a good installation video on there website.
