WestCoastDriver
So. Calif.
2025 Maverick Hybrid
Drawing on insights from Maverick newsgroups, owner forums, trade publications, and official Ford resources, here are some useful tricks, tips, and hacks for the Ford Maverick.
Got another one? Disagree with something? Please comment... YMMV
— General Driving Hacks
  • Reverse Camera for Precision Parking
    Use the reverse camera when pulling into your garage. Stop when you see the garage slab lip appear over the bumper, ensuring maximum space in front and safe clearance for the garage door.
  • Infotainment System Reset
    If your infotainment screen freezes or Android Auto malfunctions, hold the radio power on/off button and the skip track forward button simultaneously to force a system reset.
  • Auto Park and Brake Release
    You don't need to manually shift into Park before switching off the ignition. The Maverick will automatically shift to Park when you turn the vehicle off, even if left in Drive or Reverse. You don't even need to turn the car off. As long as the car is stopped, if you open the door, the car will automatically shift to park.
  • Auto Hold Feature
    Engage the Auto Hold button (if equipped) to keep the vehicle stationary at stops without keeping your foot on the brake. Pressing the accelerator releases the hold.
    — Fuel Efficiency and Hybrid-Specific Tips
  • Maximize EV Mode (Hybrid)
    To stay in electric-only mode as much as possible, accelerate slowly and use cruise control. Once at speed, back off the cruise control by 1–2 mph to encourage the hybrid system to use battery power. Modulate the accelerator to keep power usage at about 10% or less for extended EV driving.
  • Optimal MPG Driving
    Owners report achieving close to 60 mpg by cruising at 40 mph or less and using gentle acceleration. Averaging 45 mpg is possible with careful driving.
    — Comfort and Convenience
  • Sound System Improvement
    Enhance the base sound system by switching the sound mode from 'passenger' to 'driver' and adjusting the balance to favor the dashboard tweeters. This tweak can noticeably improve audio quality.
  • Seat Warmer as Food Warmer
    Use the passenger seat heater to keep takeout food warm on the drive home. Secure the food with the seatbelt to prevent spills.
    — Tech and Customization
  • Disable Automatic High Beams
    If you find the automatic high beams activate too readily, you can temporarily disable them by pulling the turn signal lever towards you while the headlights are on. Permanent deactivation can be done through the vehicle settings in the screen menu.
  • Backup Camera Zoom
    When using the backup camera, tap the "+" icon in the upper left corner of the screen to switch to a straight-down view—useful for hitching assist or parking.
Waterick
Richard
Laurens county SC
To avoid the seat belt nanny, buckle all rear belts even when not in use (Plus your own) before starting!
The Real Maverick
Jack
USE THE EV COACH SCREEN for maximum EV drive time and overall higher MPG.
On a warmed hybrid engine, turn off the gas engine anytime you want by lifting your foot off the go (gas) pedal.
More EV minutes is maybe more important to higher MPG than more EV miles.
If your wheels are not turning, your engine should be off after warm-up.
For maximum MPG always drive the last mile in EV.
For shortest warm-up the next day and highest MPG always drive the last mile in EV. It is beneficial to "give the truck something to do" IE recharge during warm-up.
The catalyst is warm enough to reduce emissions within 30 seconds of a start. The truck is ready for normal driving and normal recharging after 30 seconds.
The Real Maverick
Jack
Tailgate halfway down by moving the cables is for carrying sheet material like plywood, but for some it is also helpful for attaching a trailer because it moves the reverse camera.
There is a setting to leave the reverse camera on while traveling forward.... up to 5 mph. Called "camera delay".
Tim d
Alpena
Ram
  • Auto Hold Feature
Thx! Did not know some of these.
The Real Maverick
Jack
Keypad users:
5 digits of your choice or Ford's opens the driver's door.
Add a sixth digit, always a 3 at the end to unlock all doors and the tailgate.
Press the bottom two buttons 7/9 simultaneously to lock all.
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
i just push the camera button while driving, at any speed, and it will show the reverse camera. useful for when the back window is blocked.
The Real Maverick
Jack
Slippery mode is the gentlest of any mode and is safe to use full time.
Once you are used to the characteristics there is no mode for higher MPG.
Worst to best MPG (hybrid)
Sport - Normal - Eco - Slippery
Tow
The Real Maverick
Jack
Not all years or trims have that.
