DanO.
Dan
Idaho
2024 Maverick Lariat Hybrid
Windshield wiper tip-Use your hands to manually move the windshield wipers 90 degrees so the blades are pointing straight up and down on the windshield. You can then lift the wiper blades off the window and change blades. When finished put the blades against the window and manually move the wiper back to the off position. You are good to go and the wipers will work as usual.
Bill429
Islamorada, Florida
2026 Ford Maverick Lariat
Drawing on insights from Maverick newsgroups, owner forums, trade publications, and official Ford resources, here are some useful tricks, tips, and hacks for the Ford Maverick.
Got another one? Disagree with something? Please comment... YMMV
— General Driving Hacks
  • Reverse Camera for Precision Parking
    Use the reverse camera when pulling into your garage. Stop when you see the garage slab lip appear over the bumper, ensuring maximum space in front and safe clearance for the garage door.
  • Infotainment System Reset
    If your infotainment screen freezes or Android Auto malfunctions, hold the radio power on/off button and the skip track forward button simultaneously to force a system reset.
  • Auto Park and Brake Release
    You don't need to manually shift into Park before switching off the ignition. The Maverick will automatically shift to Park when you turn the vehicle off, even if left in Drive or Reverse. You don't even need to turn the car off. As long as the car is stopped, if you open the door, the car will automatically shift to park.
  • Auto Hold Feature
    Engage the Auto Hold button (if equipped) to keep the vehicle stationary at stops without keeping your foot on the brake. Pressing the accelerator releases the hold.
    — Fuel Efficiency and Hybrid-Specific Tips
  • Maximize EV Mode (Hybrid)
    To stay in electric-only mode as much as possible, accelerate slowly and use cruise control. Once at speed, back off the cruise control by 1–2 mph to encourage the hybrid system to use battery power. Modulate the accelerator to keep power usage at about 10% or less for extended EV driving.
  • Optimal MPG Driving
    Owners report achieving close to 60 mpg by cruising at 40 mph or less and using gentle acceleration. Averaging 45 mpg is possible with careful driving.
    — Comfort and Convenience
  • Sound System Improvement
    Enhance the base sound system by switching the sound mode from 'passenger' to 'driver' and adjusting the balance to favor the dashboard tweeters. This tweak can noticeably improve audio quality.
  • Seat Warmer as Food Warmer
    Use the passenger seat heater to keep takeout food warm on the drive home. Secure the food with the seatbelt to prevent spills.
    — Tech and Customization
  • Disable Automatic High Beams
    If you find the automatic high beams activate too readily, you can temporarily disable them by pulling the turn signal lever towards you while the headlights are on. Permanent deactivation can be done through the vehicle settings in the screen menu.
  • Backup Camera Zoom
    When using the backup camera, tap the "+" icon in the upper left corner of the screen to switch to a straight-down view—useful for hitching assist or parking.
How do you use the backup camera when pulling into your garage?
Bob W
Sun Lakes, AZ
2016 Kawasaki Versys 1000 LT
The Real Maverick
Jack
WHY? I pulled dead guys head back through the windshield when I was 20 and on the EMS. I have worn my seat belt every since.
You are not paying attention.
You need to buckle EMPTY seats (as well as occupied ones).
This keeps the message and chime off.
Tall Hobbit
New Mexico
2024 Ford Maverick XL Hybrid w/ copilot 360
Only for MY25 Mavericks with the 360 camera function.
Would appreciate if there were a hack for this for older less-equippped models, because rear visibility in Mavericks is, well, shite.
Waterick
Richard
Laurens county SC
I have been a regular seat belt wearer since 1966. Enforced by life growing up as a military dependant, I just assumed a driver (or any occupied seat) would be belted. These nannies caused by those that won't save themselves really are unfair to the rest of us. The point is to not to have to put up with the nanny for the empty seats. Edit: Yes, the rear seats do play a part. Even when they are unoccupied, they will create the nanny if not buckled. The front passenger seat does not do this, because Ford spent the money on the needed sensors I'm guessing.​
The Real Maverick
Jack
The pop up is annoying. But it only cares about occupied seats and will turn off on it's own or push ok.
Wrong Mr. Grumpy.
But thanks anyway.
Waterick
Richard
Laurens county SC
Which part is wrong? Mine shows OCCUPIED seats latched or not. And it goes away after a couple of minutes. If you claim I am wrong show facts to support your hypothesis or shove it!
No disrespect here, but if the rear seat is buckled and unoccupied, you will never even see the seat belt nanny on the dash so long as you are buckled in ( try it). If the rear seat is unoccupied and not buckled you will see the nanny even if the front occupants are buckled in. Yeah, I know it goes away with no action. However, it does cover the screen for other actions I might need/want to "OK" before driving. It also makes the driving mode harder to see when selecting each time you drive if you don't use Ford's default mode. I usually use "slippery" or "Eco" mode.
Waterick
Richard
Laurens county SC
Pull into the garage, farther than you need to, then flip into reverse and watch the camera. Adjust as necessary.
If you can't pull in that far, you can select the camera delay mode and activate the rear camera momentarily by selecting reverse before driving forward into the garage while monitoring the camera for the correct spot. I use this to ensure I'm within my parking space when parallel parking also.
