- Nov 5, 2021
- British Columbia, Canada
- 2022 XLT Maverick Hybrid
- Engine
- 2.5L Hybrid
Back in the fall of 2021 through spring of 2022 a lot of posts here at the MTC were about the factory bed liner options for the Maverick, everyone wanted the spray in liner! When I placed the order for my Maverick in the fall of 2021 Ford suddenly put a hold on the spray in bed liner as part of the XLT Lux package, swapping it for the modular plastic drop in bed liner. At first this bothered me a lot, since the common consensus from owners of older trucks was that drop in bed liners were bad, would scratch the plant and in the end would cause the bed of the truck to rust out. When my truck came in July 2022 I was skeptical, but I could tell it was much better made than the other drop in liners that I've seen in other trucks, including other Ford models. Only time and use would tell the real story.
Let's get the most common myth, that drop in bed liners cause truck beds to rust out, out of the way first. Today I took out the liner for the first time since I bought the truck, which was a rather involved process with my Maverick since I had to remove the Elevate Rack system, Ford factory sliding aluminum bed rail system, and Bakflip MX4 hard folding cover to even get started on the process. Taking the liner itself out, and put back in was rather easy. I didn't remove the front panel since it is attached with 3M automotive tape from the factory. I have put a black hard plastic protective tape on the rail below the window that overlaps the gap between the liner and the front of the bed, so there shouldn't be anything between those parts.
I own a small landscape business, so the bed of my Maverick gets well used with tools, plants, green waste removal, along with bulk soil and mulch loads. Needless to say the bed of the truck gets dirty, and due to the previously mentioned stories about rust in the bed from plastic liners I had a growing concern about this being possible. Given how long it took to get the job done, 4 hours in total, I think I can safely wait another 2-3 years before cleaning under the liner again. Please keep in mind I use a bed cover whenever I don't need the bed open. If you do not use a bed cover it could be worse, maybe?
The image below is what the truck looked like when I removed the cover today, no dusting or using a blower to clean it up. A little bit of dirt and some flakes of mulch, that's it. No scratches, no rust, and no dents from throwing in heavy items. The most dirt was where the D-rings attach at the front of the bed, since that area is open for stuff to go through. Using a tarp when loading materials in the bed will mitigate how much gets in that space, and keeps stuff out of the tailgate gap. If you don't have the D-rings stuff getting in that space at the front of the bed shouldn't be an issue other than where the panels meet.
The liner itself isn't perfect like day one, but that is it's job and it's been rather easy to clean when it was required. There is the odd scratch, and some rust spots from wet tools on the liner. Other than the fact that the factory plastic drop in bed liner is smooth and stuff rolls around it's been great. Wooden dividers help with that a lot. Not much else to say about it than that, hope people find this review helpful.
I give the Ford factory modular drop in bed liner a 9 out of 10 review.
Below is what modular factory liner typically looks like between cleanings.
