Glad to see you're enjoying your Maverick!New personal best. Just normal driving, not attempting to hypermile or anything. The warmer Midwest temps certainly seemed to help.
What that 17 miles on the road coming down for Charles Mound? (smile)New personal best. Just normal driving, not attempting to hypermile or anything. The warmer Midwest temps certainly seemed to help.
That'd be nice. Unfortunately, it's my morning commute into work. Was averaging anywhere between 45-50mpg during the winter.What that 17 miles on the road coming down for Charles Mound? (smile)
Ya, or forget all that and use Slippery Mode. All the gains; none of the pains.
OK, me too.
I find ECO mode to be best; with a caveat. I heavily modulate to go pedal to avoid max regeneration and encourage coasting; otherwise rely on regenerative braking for coasting towards stop when safe. While lessened regen may happen naturally in Slippery mode, I prefer using the max regen at times and subjectively believe there is a further delay to ICE cut-in with ECO mode. (Is there any evidence suggesting Slippery Mode does or doesn't increase/apply differential braking in turns?)
Out here in hill country, with 1000' "mountain" climbs, 700 miles per tank is nearly unachievable. The uphill climb sucks up lotsa gas. The downhill coast isn't quite enough to efficiently recover spent energy (no real surprise). You bay area flatlanders could try up and down CA-9 from Saratoga to skyline to simulate my normal conditions out here.
A word of caution for those that try ECO. ECO mode regen "brakes" hard when engaged AFAIK without brake light warning to the people behind you. Your sudden loss of speed and their rapid closure has caused a few scares with fear of being rear-ended. Be careful when in traffic in ECO mode; either modulate accelerator pedal to delay full-on regen, or very lightly apply the brake pedal. When first playing with ECO mode, I felt it to be nearly un-drivable before learning to very delicately apply pedals.
not being snarky, but can you please explain why Slippery mode is better than ECO? Maybe I missed something (wouldn't be the first time )Ya, or forget all that and use Slippery Mode. All the gains; none of the pains.
From my experience (following GPSman's advice), the best way to extend your mileage is to not use either ICE or battery power. Slippery mode lets your "coast" a lot longer than any other mode, while still getting a reasonable amount of charge to your battery. I typically use the ICE to accelerate to about 1-2 mph above the posted limits, the lift off fairly sharply to go into "coasting" mode, then very slowly increase the throttle to engage the electric mode, and ride that battery as long as possible.not being snarky, but can you please explain why Slippery mode is better than ECO? Maybe I missed something (wouldn't be the first time )
longer coasting time...yeah, makes sense, thanksFrom my experience (following GPSman's advice), the best way to extend your mileage is to not use either ICE or battery power. Slippery mode lets your "coast" a lot longer than any other mode, while still getting a reasonable amount of charge to your battery. I typically use the ICE to accelerate to about 1-2 mph above the posted limits, the lift off fairly sharply to go into "coasting" mode, then very slowly increase the throttle to engage the electric mode, and ride that battery as long as possible.
You also learn to anticipate stop signs (or red lights) ahead, and "coast" to a stop with minimal braking action - letting the vehicle's inertia recharge the battery as you slow.
After a while, you can start anticipating when the battery will need recharging, and the ICE will engage. I try to time it so I do that when I'm going to be going uphill anyway (which almost always causes the Maverick to engage the ICE anyway). That way I'm not "wasting" battery power trying to climb a hill it won't handle, and thus depleting the battery which would make the ICE have to run longer to recharge it more.
It's a delicate dance, but it's a lot of fun learning to anticipate the programming, and after a while it doesn't take nearly as much thought - I guess it becomes "muscle memory"...
GPSman is MUCH better at this than I am, likely helped by the ScanGuage III instrumentation he's added to his Maverick. I'm hoping to get one for my birthday later this month...
Insightful comments..and worthy to try out. Thank you.So much of what has been said is accurate and useful. However, it may not all universally apply.
Max regen is not a (worthy) goal. Avoidance of friction braking is. Vehicle control and stability are also.
All situations vary and use of Eco mode is preferential in mine. Until a manual states what is actually happening, each of us can have our own subjective views and experiences. Mine, like the terrain around me, are different from yours. However you wish to 'play' your truck is fine by me.
Use of Eco mode allows painless use of regen to control downhill speed. This is not stoplight to stoplight control, but speed limiting on a 1000' foot descent before ICE compression (another waste). The constant speed aspect of Eco control is very, very nice. The energy recovery (vs braking) is is not something provided by slippery mode. Slippery mode would accelerate on the downhills and require braking (to obtain regen) or friction braking. Nothing is for free, Eco mode requires effort of modulating the go pedal to avoid regen when costing is preferred. This how I 'play' my truck and works best for me. YMMV.
(( Go ahead and try hwy9, hwy92, page mill rd. Then comment on Eco vs Slippery. ))
Of course. Done all that.So much of what has been said is accurate and useful. However, it may not all universally apply.
