Mav
E
Earth
Lariat Maverick
Found on Amazon. The only aftermarket high flow filter I’ve found yet. There’s more intake and turbo noise. It definitely sounds and feels like it’s breathing better. The best part of this filter is that it’s still enclosed and allows you to retain the factory airbox and plumbing that pulls fresh air from outside of the engine bay.
K&N Engine Air Filter: High Performance, Premium, Washable, Replacement Filter: Compatible with 2018-2020 FORD (Escape, Focus IV), 33-3131
Air Shootist
IL
Fully loaded 2022 Maverick Lariat
I've had this in my cart for months.... Now if I could only TAKE DELIVERY OF MY GD TRUCK
Area51BS
Ron
Performance improvement?
  • Like
Reactions: Mav
CraigMN
Minneapolis, MN
Toyota Highlander
Amazon reviewers said it will decrease MPG - that’s the trade off.
Decayed
yes
a car
Gonna be my first purchase after taking delivery. I'd love to see dyno numbers it should help.
  • Like
Reactions: Mav
Mav
Mav
E
Earth
Lariat Maverick
By found, you mean given the part number by yours truly? Just kidding.. glad it worked out for ya.
A high flow filter will not decrease MPG. The only way MPG will decrease is from a change in driver behavior (driving more aggressively because of the desire to hear the new intake sound), or if the filter is overly-oiled out of the box, in which case is a simple fix.
Agreed. Free flowing intake improves MPG. Unless you can’t resist getting into the throttle because now you have a race car.
Edit: meant to say improves efficiency. Which unfortunately means you may burn more fuel by volume.
Mav
Mav
E
Earth
Lariat Maverick
JChristiansen
2019 Subaru Ascent
Is wish there was one avaiable for the Hybrid but K&N does not have a part number yet!
STARCOMMTREY1
Trey
Boligee, AL
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Brian_J
Akron, Ohio
I don't have a dyno...:confused:
Most people don’t. Find your local tuner shop with one and have them dyno it. Make sure you get the air fuel ratio read out too.
Decayed
yes
a car
Maybe in the spring when I'm likely to see my order filled.
  • Like
Reactions: TCK
