40mpg - Tested or Estimated?
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis LS
oljackfrost
Minnesota
How does the hybrid offer any benefit (increased fuel economy) on the highway?
The advantage is that the gas engine combined with the eCVT can be controlled by the electronics to run in the most efficient RPM range possible for a given speed. That’s why the hybrid has a higher MPG on the highway than the turbo. Hybrids always have higher city MPG because the electric motor is being used more, either by itself or in combination with the gas engine.
FirstOnRaceDay
Devin
Toledo Ohio
That and the hybrid has a 2.91 rear end 3.63/3.81 in the turbo. That helps the highway milage a lot!
oljackfrost
Minnesota
jwiedle24
Ohio
Lariat w/Luxury Pkg
Does it benefit from using adaptive cruise control — does that allow for some regenerative braking on the highway or is it too minimal to hand an effect?
FirstOnRaceDay
Devin
Toledo Ohio
Absolutely. Adaptive Cruise is more likely to apply regen braking early and often to adjust speed vs you using the brake pedal. Will keep the speed more consistent
Tennessee
Tennessee
Ford Fiesta ST
Like many hybrids the Maverick uses an Atkinson cycle engine. This type of engine is a lot more efficient, by some estimates up to 40% efficient at converting gasoline to motion. Atkinson cycle engines suffer from low torque at low RPMs, which benefits greatly when used in combination with hybrid electric drive. The electric motors have outstanding low-end torque.
Maverick-xv
PA
2003 Expedition XLT
Escape Hybrid, the Maverick Hybrid is based on, delivers 44 MPG, so 40 MPG on Maverick Hybrid should not be an issue.
oljackfrost
Minnesota
Just like the VW diesel forums, pretty soon we’ll be posting photos of our instrument panel MPG readouts and bragging about our mileage 😁
Art_Vandelay
Queens, New York
Maverick Hybrid Lariat, Subaru WRX
Reminder that if you live anywhere with a winter climate you will see a drop of a few MPG during the winter months. When it’s cold, the battery won’t hold a charge as well and the engine needs to run more to provide the cabin with heat.
oljackfrost
Minnesota
In some states, like Minnesota, gas is required to be “oxiginated “ in the winter for emissions purposes. Simply this means that there is alcohol added... alcohol has less energy density than gas, so mileage will decrease in all vehicles.
Wire4money
Las Vegas
2005 Wrangler
Pretty sure it is all oxygenated now. I don’t know of any states not selling fuel with 10% ethanol.
CLH917
Travis
Madisonville, LA
Louisiana. Within about 6 miles from me there are 5 ethanol free gas stations.
