Mas280
I added a 12v and 110v outlet in my Maverick XL. I used a Ram 1500 400w inverter with Nissan Titan bed outlet. I didn't want to use a aftermarket inverter as they can be loud compared to oem inverters. Unfortunately my truck did not have the factory inverter harness so I ended up making my own. I mounted the inverter behind the rear seat. The 12v outlet is wired to the harness that's already in the bed.
Parts used
Ram Truck inverter 400w
Bed outlet harness 253A0-7S200
110v power outlet 253A47S200
12v outlet
Ford Maverick 400w 110v bed outlet added 333
Ford Maverick 400w 110v bed outlet added 444
Ford Maverick 400w 110v bed outlet added 111
Ford Maverick 400w 110v bed outlet added 555
Ford Maverick 400w 110v bed outlet added inverter
Traegorn
Trae
Eau Claire, WI
www.nerdandtie.com
2023 Ford Maverick XLT Hybrid Lux/360
Noice!
Mas280
Mas280
So my Maverick XLT (not here yet) was ordered with the 110v in the cab, but not the bed. Has anyone tapped into the existing 400w inverter and run it to the bed?
That would be a easy upgrade.
wyouger
Williard
2011 Ranger
I like it. Very nicely done. Is there a reason that you did not use a higher wattage inverter.
STARCOMMTREY1
Trey
Boligee, AL
Write up of install?
Jwhisl
Tulsa
2014 f150
This is what I'm talking about! Adding features and using creativity! Very cool. I wonder if there is a way to put in a higher output inverter? I sometimes need to run power tools and that would be super convenient
Decayed
yes
a car
Y u no post pics of install? How did you wire it in?
bbhaag
What was the cost of the Stellantis inverter and how long did it take you to install it?
Mas280
Mas280
I ran heavy gauge wire so I could upgrade the inverter at a later time. I wanted to run a factory inverter to keep it quiet.
The inverter was $40 on ebay and I spent two hrs on the install.
Flomounier1
Los Angeles
2022 Ford Maverick Hybrid
This may be a dumb question but I'm assuming both of those outlets only have power when the vehicle is ON and running, correct?
