'22 Snotty Litte Bastard build
volksnuts
Katy,TX
Maverick Lariat HPR
Nope, normal version. Preload was/is fine. It's not the spring rate that makes it a bit bouncy, it's the damper; to be fiar, however, I am coming out of a German car with very high-end track suspension. Not a fair comparison. The ride on these reminds me much of almost every Japanese tuner car I've driven.
So far there have been no complaints about the normal version which seems to offer the same drop as the low version yet keeps a decent ride
Truck looking good btw
Dallas Maverick
Dallas, USA
Volvo
Dr.Carvorkian
Anthony
Pullman, WA
Think the Mav would be fine with 18x9.5 wheels at stock ride height?
Absolutely, at least at stock tire diameter of 29". I got no rub at all at stock height. Now with the drop, I get a slight rub at high steering angles, but not enough to effect my daily driving.
With my particular setup, there was absolutely no rubbing at all when at stock height. But the wheel offset and tire diameter certainly effect how things fit. My wheels have a 22mm offset, meaning they sit out further than the factory wheels. My tires are 255/55/18, which are the same diameter as stock, just wider. Changing the offset and/or the tire may cause a rub, but I can't comment since this is the only setup I've used.
chilicoke
S2000
Looks super sharp! I'm set on that size tires whenever mine comes. Did you had to mod your hubs to 5x114.3 or where you able to order those wheels in 5x108? thanks!
Dr.Carvorkian
Anthony
Pullman, WA
I was able to order a 5x108. They had 2 offsets available; mine is +22. I am running hubcentric rings in the front, and hubcentric 10mm spacers in the rear to get the stance close to square, the rear track is a bit narrower.
chilicoke
S2000
Awesome that's good to know, thank you very much! No idea when mine will show up but I was already pretty disappointed with availability of 5x108 wheels and was ready to order extra hubs and redrill them into 5x114.3.
Dr.Carvorkian
Anthony
Pullman, WA
Just installed: Bushwacker fender flares, along with 40mm front and 50mm rear wheel spacers from BORA. A bit of fender liner rubbing on tighter turns, but not terrible. The body shop will do a little trimming to clearance in a couple of weeks. With the wheel offset, track width is now nearly 6 inches wider than stock.
Ford Maverick '22 Snotty Litte Bastard build 20221110_140654
Ford Maverick '22 Snotty Litte Bastard build 20221110_140712
Ford Maverick '22 Snotty Litte Bastard build 20221110_140819
Ford Maverick '22 Snotty Litte Bastard build 20221110_140726
profecia
South Florida
Maverick Lariat
which spacers did you purchase? Looking to add some on my truck.
profecia
South Florida
Maverick Lariat
The brand is BORA. They will custom-machine spacers to your specs. Turnaround time is just a few weeks.
Thanks! Dis you end up needing extended lug studs/bolts? If so, can you share which ones? I’m a bit lost on this spacers topic.
Dr.Carvorkian
Anthony
Pullman, WA
BORA sells spacers that have integrated studs, depending on the width and style you specify. Check out the website; you can also specify a different bolt pattern if you want to use a wheel that isn't available in the factory pattern.
E30andrew
Andrew
Lafayette, Louisiana
'23 XLT FX4 EB
damn! truck is looking awesome. Really diggin the vibe, nice build.
MavFromTheDead
Derek
Leander, Texas
XLT Tremor
Sick Mav. Maybe my favorite build yet.
