2025 Mav keyless entry
JohnnyBravo
D
New York
225,000 mi. Honda CRV
I've noticed that ford is trying to save a few bucks by not including keyless entry on the lariats anymore. sad. I've also seen that the mounting location is now on the door above the handle. I prefer the pillar mounted keypad. Does anyone know if the 2022 keypad will work on the 2025 models?
JohnnyBravo
JohnnyBravo
D
New York
I looked at the doors....they look to be the same.
Dave O
New Smyrna Beach Florida
Being these keypads are wireless I assume the location is flexible? Are there distance restriction? I would maybe consider mounting this out of sight on the trim on the rear of the cab any one else installed in a creative location?
Magicsteve
2025 Maverick Lariat
I’m going to try for inside of the gas tank door.
Only works for eco boost as you don’t have a lever to pull on the insode of truck.
mine should be here any day and my dealership is only programming and not sticking to the truck.
Dave O
Yeah that’s creative for sure, my gas door is locked as you mentioned so I was looking to install it out of clear sight
The 22-23's had a different door, which had a recess for the keypad. It wasn't just a stick-on.
HRG
Here is a picture of a Maverick factory key pad door. Look to me like a press punched hole is made during the manufacturing of the door.
Ford Maverick 2025 Mav keyless entry 20250220_100152
B. Adams
SD
2025 Lariat AWD
Ford doesn't offer a wired keypad on any vehicles now, as it saves them from having to punch holes in some of the doors, and the cost of wiring it up. I have a wired keypad on my 2017 F350, and it's kinda nice, but I rarely use it. A new F350 wouldn't have one, and it's not an option. I didn't add the wireless keypad on my Maverick, which is fine for me, as the proximity keyless entry works well.
The batteries in the wireless keypads are non-replaceable, officially, but I've heard you can get them open if you really want to. I've also heard that the battery should last around 5 years under normal use.
JohnnyBravo
JohnnyBravo
D
New York
interesting. My 2022 lariat keypad was not recessed like that....and I thought it was wired.
To replace the batteries in the stick-on keypad is a little more involved.
Ford didn't want to make it so easy. That anybody could come up, pop the cover off, take the battery and you end up being locked out. 😳 Not that it would actually happen.
This is an old thread. I'm willing to bet not much has changed.
https://www.fordtransitusaforum.com/threads/ford-keyless-entry-keypad-battery-replacement.100038/
Does/did your keypad look like mine?
Ford Maverick 2025 Mav keyless entry 20250218_080011
The plug and guts of the keypad are on the inside of the pillar.
The buttons, faceplate and gasket are on the outside of the pillar.
