2025 Lariat Fog Lights
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
If somebody can fit the LOBO fog lights with my tow hooks, sign me up.
I have the tow hooks on my lariat and fit the DD Kit. The problem with the LOBO fog lights is the housing they come in doesn’t work well to be able to fit because it’s a completely different shape. Could it be done, probably, but as much as a pain as these were, the LOBO lights would be even worse. @710-oil-614
Jhmcclos
Berlin, CT
2025 Ford Maverick Lariat
For all you haters out there that said the DD kit wouldn't fit a 2025!!!
BTW - Lobo has fogs.
So you did get the Dd fog lights to fit. I see in a video that the entire bumper did not have be removed? Can you confirm that please?
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Yessir, I purchased the DD kit for the 22-24 Mav and cut it and worked with it to make it fit. I’ve never liked flush mounted fog lug lights on the bumpers so I made it to where it fit in to the hole. That way I could get the “factory” look.
as for the bumper, you only have to remove the lower plastic and the trim piece on the front of it. The upper front bumper under the lights does not need to come off. I only pulled it off because the CVF FMIC was installed as well
Frenchy6784
Jean-Louis
Galt, CA
2025 Maverick lariat
did you use dd's instructions and template or did you modify it? If you modified it could you supply the template to all of us 25MY owners who want fog lights? DD just doesn't seem to be overly interested in helping us.
710-oil-614
Cal
2025 Hybrid AWD Lariat
LOL man the vehicle has only been out for 3 months it takes time to design and manufacture things....
Frenchy6784
Jean-Louis
Galt, CA
Weathech did for their lampgard they’ve been on my truck for 2 months
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
I have not used their template. I will be wiring them and using a stock F-150 switch in the cabin for a completely stock look. If I’m unable to figure it out there are some Maverick guys in my area that I will seek help from
sg777
tracy
mississippi
2025 maverick tremor
I tied mine into the lights. Headlights go on, fog lights go on
envymy300
Cody
Fredericksburg, VA
2025 Ford Maverick
Can the Maverick Lobo lights & switch be added to a Lariat?
You might be able to make it work, but the LOBO Fig Lights will definitely require more fabrication. The housings are very different shapes. The F-150 switch is the same as the LOBO switch if I’m not mistaken
FischAutoTechGarten
Peter
I wonder if the lower valance of the Lobo could be added to the Lariat... and then the fog lights should mount... Any hardware should be transferrable, no?
I guess it's similar to those who bought a lower FX4 Valance and hooks to fit out their standard XL/XLT/Lariats.
sg777
tracy
mississippi
Mabett is making a lower valence with lights in it. It's on their fb group
Sticks
Shawn
St. Louis
Many of your comments are helpful, but not this one. Please stop encouraging people with less skill than OP to waste their time and money on this.
OP showed it clearly doesn't fit a 2025 -- they had to cut it down and custom-mount it in place, which could be done with anything given enough skill, time, and money.
The average MTC user isn't going to do this -- they want products that fit to begin with.
I agree that the Lobo valence would be nice to see on other trims.
Aleks
Aleks
West Coast
I have a set of DD yellow fogs on a different vehicle, and the moment they come out with a kit for the '25 mav, I'm ordering them.
