2023 Lariat Hybrid no cruise control
Johnkn
MD
Will double check grey indicator next time, have been looking for green like my F150. Thanks
Assuming your Lariat is like my XLT, on the left side of the steering wheel is a CC 'Set" button with a "+" above it and "-" below it to increase or decrease speed once set, however to the right of the "Set' is the master cruise control Icon button. Make sure that is enabled, then try "Set", but you need to be traveling above a certain speed, so try a higher speed like 50+ .
Cruise control needs to first be enabled or armed, then set to the desired speed....
On the 2023 Owners manual, page 220, very bottom of left column..
good luck
Johnkn
MD
Should a green light with cruise sign come on dash when cruise button is pressed?
Thanks
Yes, as long as the master CC Icon switch is enabled and the "Set' is pressed.
good luck
samspritzer
Sam
Buffalo NY
2019 CRV
Did you activate the CC by pressing the button to the right of the "+" button?
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
My son just picked up his Lariat hybrid and not long after our 4 hour ride home he hit the cruise button and nothing happens. Anyone had this issue?
Thanks
The on/off button is the upper right hand button in the left hand side of the steering wheel.
If CC is on, the indicator looks like this on a Lariat hybrid (see attached picture). If the speed is set, there is a MPH indicator as well. It will turn green when the CC is active.
Use the RES button in the left hand side of the steering wheel to SET the speed (toggle it UP or Down). You must be moving at least 20 MPH to set the CC speed.
Once set, a quick toggle of the RES button, either UP or Down, will change the set speed in 1 MPH increments. Holding the toggle longer than that, sets the speed in larger increments and can be surprising.
Good luck
Ford Maverick 2023 Lariat Hybrid no cruise control KIMG0176 (2)
TomD
Thomas
Jeep Cherokee Trailsport
Thanks
The cruise control took me a couple of tries to figure out. There are a lot of things on truck that are a little cryptic.
I had to go to my dealership for remedial Maverick because I couldn’t figure out how some things work.
commadorebob
Yes, the F-150 has a different cruise functionality for some reason. But the Maverick is exactly like the Escape I traded in. So, I was able to figure it out without much thought.
Joliet Mike
JolietMike
Morris Illinois
Own 2023 Lariat Eco...Ordered 2023/24 XLT HYBRID
Thanks
Yes, lower left with a slash thru it till you set speed. If your use to the old Ford cruise it is quit different. Toggle instead of pressing the up and down buttons.
Mavboy2023
Jason
Nebraska
2023 Maverick Lariat Hybrid
Thanks
Try reading the Owner's Manual....a wealth of info to be found. A horror, I know.
Old Man
Nebraska
2023 Lariat
The Hermosillo plant has a test track where they test random Mavs and Sports but not big enough to test cruise. Maybe some miles were put on there.
Four hour drive home from picking it up new? Did you read the break in procedure in the manual prior to picking it up?
mitch42
mitch
florida
22 F150 BAP Platinum
I will post back when I get the cruise figured out. Thanks for the helpful responses
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
mitch42
mitch
florida
Hooked foscan up and got into sccm data and all switches on the left function except the cruise on button. Will update from here. Thanks
Stillman
Don
Stillman Valley
Mavrick
Thanks
Good thing you have difficulty with the cruise. It's not a good thing to use during the break in period.
mitch42
mitch
florida
I replaced cc switch and all is well now.
Thanks
