2022 Maverick Left Side Mirror Removal Replacement - DIY video
Gunny.salazar
Victor
San Antonio
2022 Maverick XLT Hybrid, 2022 Explorer Limited
Hi fellow Maverick owners and soon to be owners! I documented a video of the replacement of my 2022 Maverick driver side rear view mirror. I recorded it since I could not find any videos of this procedure on the Maverick. The 14 minute video is at the following link on you tube:
I purchased a painted to match mirror (Velocity Blue), even though my original mirrors are just plain plastic. I will paint to match the right side mirror once I purchase a quality can of E7 paint code aerosol. I noted upon inspection of the electrical connectors that the replacement mirror has two more pins than the original one on my Maverick. However, after I connected everything, the power mirror controls worked... most importantly, the "warning lights" for the blind spot and safety perimeter sensors went away. After a brief test drive the little BLISS icons were lighting up anytime a vehicle approached me from my blind side. Everything works perfect as intended.
You may be wondering why I'm replacing the mirror; well I was stopped at a red light with my baby in his car seat in the back, suddenly a piece of shit driver decided to run the red light and came flying from behind me smacking my mirror and ripping it off. Since I was with my newborn baby in the truck, I decided that it was not worth it to give chase to this ducking idiot. I called police and filled a hit and run report. Damages were lower than my deductible so hence I'm doing my own work. I do hope that driver gets hit by a train.
Disclaimer, I'm not a you tuber or social media creator, so the quality of my video and editing may not be to the standards you would expect of those channels; I used one hand to hold my phone and the other to hold/work with my tools. Speaking of tools, you will need a 1/4" ratchet, 4 inch extension, 10 millimeter socket, and a couple of interior trim prying tools made of plastic. It will also help if you have a small rag to stick in the panel opening seen once you remove the sail panel, this will prevent you from dropping any sockets or nuts into your door panel, never to be seen again! You will see what I mean. Now I know what happens to all those 10MM sockets LOL... :ROFLMAO::ROFLMAO::ROFLMAO: Thanks and please post you respectful critical comments if you desire. Semper Fi!
Gunny.salazar
Gunny.salazar
Victor
San Antonio
Here’s some pictures of the original and replacement mirrors.
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 7AE8AAC7-28EC-42CB-874B-1E42D0DB908F
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video FCC02BF3-C679-4D83-A6FC-D0E60D353CF1
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 6CEC1E3E-F0D3-4386-90CD-2882CCCBFF98
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video B3C824C7-B538-4180-B6A2-2AE8BDE889EE
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 619C22FC-BB25-41D2-9579-704DC2674FA6
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video E38AD3E8-0078-45E8-9F85-7200C396DE3E
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 0DA1E293-3F9C-4552-91A5-F00E7A7599BD
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 1815B8D7-8282-4703-B9AF-0575685482E3
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video F53E12F6-0A2A-47FE-9CC9-FA9D85F81E9D
Ford Maverick 2022 Maverick Left Side Mirror Removal Replacement - DIY video 77ABA5D6-74C0-484F-8637-184A4908B2C4
jonathan1994
Jon
Laurel MS
2015 Taurus Limited
I want to install puddle lights, but it looks like the mirror housing can't be opened?
skadizzle
Orlando, Florida
2023 Ford Maverick Lariat BAP
I am thinking of swapping my side mirrors myself. I have an Atlas Blue with the BAP coming and don't really want the black mirrors. I'd rather have the body color ones. I'll probably see if anyone on the MTC wants to swap mirrors. Otherwise, I'll probably wait for one to show up in the junk yard.
gmflash88
MN
XLT/FX4
Not to dig up an old thread, but my idea/plan for puddle light brought me to this video. I looks like you could drill a small hole facing downwards under the BLIS clip that will allow wiring to fish down the door gap and through the loom in the door into the engine bay. I'd put a very small LED in the mirror arm and not the mirror itself. Fish the wire and connect it to the cargo light. Problem is, I don't know where the cargo light fuse/control is as I haven't received the truck yet.
Another option, if your truck is equipped with it, might be to tie into the power that controls the lock/unlock keypad in the B pillar. Pretty sure that lights up with hitting unlock as well but the power coming to it may be constant. Again, need my truck to play around.
In the event I figure anything out, I'll post it on the forum for sure.
Worst case...I may hook puddle and some underbody lights to an RF switch but then I'll end up with a second FOB. I have this setup on my overland trailer where one button controls some rear facing lights for backing up at night and the second switch controls some lighting under the unit for getting in/out at night. It works great, but again, on the truck, it'd be a second FOB and button press.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
This video gives me an idea to install a sequential signal lamp under the mirror instead of in the front of The grille.
Edge Haley
Edge
CARBONDALE
PORSCHE
Great job with video with one hand.
