Is this the same as old school harmonic balancer?A damper works to take out/smooth out the torque spikes from the ICE engine (not continuous but lots of little explosions!). so as we think of input shaft to damper to output shaft configuration, There will be a small expected difference between input and output shafts as the damper actually smooths out the output shaft speed. if there is something wrong with the damper, it will allow too much difference between the input shaft and output. If I had to guess, the sensors measuring shaft speed are picking that up. THink about 'flooring it' - worst case as the damper has to work the hardest to keep up to the torque change and handle the largest torque spikes. my guess is not a critical issue that will result in cascading failures, but rather a 'out of boundary'. Only risk (assuming some form of rubber) is damper is being worked at higher levels and could fail early. Unless Ford knows of critical failure that requires parking the vehicle until fixed, I would keep the car myself until parts are in - and ease off the flooring until fixed.
