12volt battery replacement?
H4 group 140R AGM or Flooded your choice.
The correct size is H4 unless you want to do modifications including, bending some metal and removing the plastic surround allowing you to install the larger H5 battery.
If you are planning on installing the battery yourself you may want to plan on getting one of these a magnetic socket from Amazon.
Amazon magnetic socket link
Give me a moment please..... this is going to be a long and involved post
Removing the battery clamp nut isn't the problem, but reinstalling it is.
As you can plainly see.
Even with the proper size H4 battery it's a tight fit.
When I eventually end up replacing my battery.
I don't know if I will remove the plastic surround or order a 10 mm magnetic socket. I would think it's harder to get the battery hold down clamp in the proper position with the plastic surround in place.
Then there is the process of making sure the new battery is charged 100% before doing the BMS relearn. This is something most places that install your battery probably will not do.
From the manual.
This is about as comprehensive a post as I can help you out with.
Good Luck.
Ih8thew82
NE Ohio
2022 XLT LUX Hybrid
Timely information for me too! My '22 XLT LUX Hybrid has the original battery and probably should be replaced before the next Ohio winter.
DWV
Don
charlotte nc
2024 Maverick
Replace with the AGM battery, choosing a flooded battery is nonsense. There must be over 100 threads on replacing a battery and/or choosing a battery- read some of them and learn why AGM is the wise choice.
