Who sells replacement battery for ecoboost trucks?
Gpp
Gil
Sanford nc
2022 ford maverick
Just wondering where uptown you can by a battery for the eco boost trucks.say napa or advance auto.just in case it dies when out of town.i assume its a special battery.
jsus
2022 Ford Escape Hybrid AWD
See your owner's manual - Capacities and Specifications - Motorcraft Parts - 2.0L EcoBoost. It's a 48H6, standard size that you should be able to find anywhere that sells automotive 12V batteries. Standard option is a typical lead acid battery, with an AGM option for extra charge. You may already have an AGM, depending on what the factory put in your truck.
Advance Auto Parts: https://shop.advanceautoparts.com/p...apacity-maximum-starting-power-48h6/2130015-P
O'Reilly Auto Parts: https://www.oreillyauto.com/detail/...-platinum-battery-group-size-48-h6/ssbq/48plt
AutoZone: https://www.autozone.com/batteries-...ttery-h6-dlg-group-size-48-730-cca/832332_0_0
And any Ford dealer, just to name a few examples.
Capacities and Specifications - Motorcraft Parts - 2.0L EcoBoost™
MOTORCRAFT PARTS - 2.0L ECOBOOST™
ComponentMotorcraft Part Number
Air filter element.​
FA-1939
Battery.1​
BHEF-48H6
Alternative battery.1​
BAGM-48H6-760
Cabin air filter.​
FP-89
Engine oil filter. 2​
FL-910-S
Spark plug.​
SP-594
Windshield wiper blade.​
WW-2249 (driver side) WW-2054 (passenger side)
1Configure your vehicle’s battery management system to match the replacement battery. If using a battery not listed, it must match the specification as one of the listed batteries. Configure your vehicle’s battery management system to match the listed battery. Failure to use an appropriate configuration for your battery management system could result in shortened battery life, features not working correctly, or your vehicle not starting. Consult your local dealer or service provider for further details.
2If a Motorcraft oil filter is not available, use an oil filter that aligns to SAE/USCAR – 36 Performance Specifications. Filter Type B.
We recommend Motorcraft parts that are available at your authorized dealer or at www.fordparts.com. We engineer these parts for your vehicle to meet or exceed our specifications. Use of other parts could impact vehicle performance, emissions and durability. Your warranty could be void for any damage related to use of other parts.
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=USA&buildtype=web
OleFordGuy
JPB17
Wisconsin
Maverick Lariat
I just got a new battery for my escape 2.0 EB. Using quick lane at the dealer, they did free install and brought out the laptop to reset BMS. It took so long I was glad to pay $20 more for the battery to sip coffee instead of tearing apart the wipers and trim. If the Maverick is anything like the Escape, the dealer is a great choice. I also know from an expert in batteries that Ford batteries are generally exceptional quality. Long warranties on cheap batteries are great, but not changing it in a bad spot is also great.
B2000
midwest
B2000
