Yeah, I see both the $189 and $94.92 versions when I search forWOW ! Great find if true, the last time I looked at Walmart it was $189 here:
https://www.walmart.com/ip/EVERSTART-H4-AGM/11166765405
Do you have another link ?
How to reset BMS?I have a '23 XLT Hybrid (35 months old, 22Kmiles). Never failed to start or gone to deep sleep, but it has been increasingly going to battery saver and cutting things like entry lights. Dealer says battery tests a little low, but not in warranty. Was in Costco recently and they had the Interstate H4 AGM battery for $137 + tax + $3 disposal fee + $15 core charge (36 mo prorated warranty, 480CCA, 52 Ahr, 75' reserve). To try to avoid problems over the winter, I bought it Monday and installed it Tuesday. Estimate it to take about 40', took me a little longer because I had a slip up. No need to remove housing, you need a long extension and a magnetic pickup. Remove the neg first then the hold down bolt & clamp, then slide the battery to get clearance to remove the Pos clamp. Remove battery and reinstall in reverse order. Then reset BMS.
I see 2 primary differences - 535 cold cranking amps and 3 year replacement warranty ($95 version) vs 540 cold cranking amps and 4 year replacement warranty ($189 version).Yeah, I see both the $189 and $94.92 versions when I search for
"EverStart Premium AGM Lead Acid Automotive Battery, Group H4"
This should work:
Free Shipping! EverStart Premium AGM Lead Acid Automotive Battery Group H4, 535 Cold Cranking Amps, 80 Minutes Reserve Capacity - Walmart.com
Both $95/535CCA (see photo) and $189/570CCA versions feature 4-year free replacement warranty (no diff in that regard).I see 2 primary differences - 535 cold cranking amps and 3 year replacement warranty ($95 version) vs 540 cold cranking amps and 4 year replacement warranty ($189 version).
Neither of those warrants double the price!
$95/535CCA version seems to be available online only (link in message #36 above).My local Walmart has the H4 AGM in stock but they all have a 3/25 sticker on them. All the other batteries are within month or so, 12/25-1 /26. $139 (US)
As stated all along, online only. Appears to still be available (I see that if I ordered one now I would receive it tomorrow with free shipping to home address). Link I provided in message #36 above works for me.I think you got the deal of a lifetime, I called my local Walmart Auto Center and they laughed at that price for an AGM battery.
That’s not what your link showed. Just a 3 year warranty but obviously the sticker is different.Both $95/535CCA (see photo) and $189/570CCA versions feature 4-year free replacement warranty (no diff in that regard).
It ships for free....Shows out of stock here locally in Georgia, not available at any store in this state.
Great for you but not sure anyone else has been able to take advantage of this deal. Maybe a local mistake ?
Clicking on the link I provided in above messages #33 and #36 (where I say "This should work: ") results in something different? Strange, that link still works for me with the battery still available for delivery to my home tomorrow. As stated originally, there are some inaccuracies/minor discrepancies (keep in mind it's Walmart Online) and no image of the $94.92 535CCA AGM battery is provided. The listing indicates a 4-year warranty (Platinum-level feature?) but I do also see a reference to 3-year. For that matter, I also see an incorrect indication that "It looks like it doesn't fit my '23 Maverick XLT Hybrid" and some other incorrect or at times conflicting references. Simply sloppy. All mentioned before. I don't see anything in Walmart's online listing today that is different from when I purchased mine in November. Photos of the battery I received show exactly what I received and the fit and all were perfect. Of course, if what I received was different or wrong, I was simply planning to return it to my local Walmart (viewed the ability to do that as one of the many pluses).That’s not what your link showed. Just a 3 year warranty but obviously the sticker is different.
