Cubican
Pedro
Ridgeline, viper, c8
I just installed a frameless Homelink mirror that is wireless install as simple as bolt on bolt off 20 torx screwdriver all is needed, is actually a Toyota part I found mine on a google Search for 80 bucks out the door prices are all over the place. There are no wiring necessary As the home link has a 10 yr battery installed in the mirror. The frameless mirror gives me a much better view out the back I can see the hole rear glass on frame. Here’s few picks with part #
Ford Maverick Frameless & wireless homelink mirror installed 88E8F194-4E19-47F8-B98D-8328EFE23D41
Ford Maverick Frameless & wireless homelink mirror installed AB21626C-6A30-4910-8500-CA7AB64F0F52
Ford Maverick Frameless & wireless homelink mirror installed 6F44752C-5F1F-4C50-9FE5-DA58BED16E8F
Ford Maverick Frameless & wireless homelink mirror installed 103FC07C-8235-4214-9662-8427C3D43E58
Lofton
Alejandro
Central IL
Is it auto dimming also?
groovesocket
Atom
Central TX
2022 Cyber Orange Ford Maverick XLT Hybrid
Nice work! Do the Homelink buttons work when the truck is off? I only want them to work when the truck is on.
bbhaag
Doesn't appear to be. The litter dimmer flipper is located on the back of the mirror next to the buttons.
Old Hickory Trojan
Ron
Madisonville TN
21 Crosstrek Spt ,23 SC AWD,02 Jeep 4x4, 17 Winbgo
I just installed a frameless Homelink mirror that is wireless install as simple as bolt on bolt off 20 tork screwdriver all is needed, is actually a Toyota part I found mine on a google Search for 80 bucks out the door prices are all over the place. There are no wiring necessary As the home link has a 10 yr battery installed in the mirror. The frameless mirror gives me a much better view out the back I can see the hole rear glass on frame. Here’s few picks with part #
Appears to have three buttons on the back what are each for? Could you clarify a bit on the mounting you went through? Also is the battery replaceable or do you need a new unit?
Deleted member 9167
Guest
Dang that thing is sweet! Hard to tell, but is it bigger than the OEM mirror?
ffoc01
2022 Mav Hyb FE, 2014 Flex
The buttons are battery powered. They work all the time.
ffoc01
The three buttons are the 3 Homelink buttons. One to control each paired device. The battery isn't officially replaceable, but I haven't tried to pry one apart myself. I'm sure there's a way to get it apart, but I don't know how much damage it would cause, taking it apart. As for mounting, I believe it's just a T20 set screw.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
It operates on a self contained battery so I imagine it "on" 24/7
Cubican
Cubican
Pedro
The buttons are for the homelink garage opene, for the install is only one screw nothing else no wires to splice the mirror has a battery to power it
SlingerRing
02 Ford Escape
*torx* screwdriver. Cool looking mirror. Futuristic
Finklejag
WA
Was it hard to remove the oem mirror? It looks like it slides downward to remove. I had cars in the past that you had to twist the base to remove the mirror, and sometimes the glass mount comes off too.
Cubican
Cubican
Pedro
It actually slides up very easy just one screw
