2025 Lariat Homelink Mirror
LimeMachines
MA
2025 Lariat Hybrid
I purchased a A7062 ADUP1, but the seller cut the connector off. I also have the harness which piggy backs off the interior lighting for the 12V supply.
my mirror has 4 wires, white, green, gray and black. Has anyone encountered this configuration and might have an idea what the pinout is?
Aaron
FL
25 Lariat AWD HYBRID
From chat gpt
Yeah, that mirror is the same basic Gentex/Kia unit everyone’s been using on Mavericks. The 4-wire pinout is:
  • Black = Ground
  • White = +12 V for the mirror/compass (main power, usually switched 12 V)
  • Green = +12 V for Homelink (you can just tie this to the same switched 12 V feed as white)
  • Gray = Reverse signal input (12 V when in reverse, disables auto-dim when powered; if you don’t care, just cap it off)
On the Maverick overhead harness people typically do:
  • Mirror black → dome light black (ground)
  • Mirror white + green → dome light white/green (switched 12 V)
  • Leave gray alone unless you want to go hunting for the reverse feed.
If you want to be extra safe, bench-test it first with a 12 V source: black to –, white+green to +, then shine a light at the front sensor and cover the rear sensor to confirm it dims. Gray should kill the dimming if you put +12 V on it.
