1" Suspension lift... Would you do it?
ZipperKid
Central Florida
Chevy S10
Now that the truck has been revealed at all angles, who is ready to take this truck "up" a notch when they receive it? From where I'm sitting, the truck looks like the axle line is below the body line and with that means you can more easily stuff larger tires with just a bit more clearance....
Now, I'm no engineer but I don't think another inch would hurt anybody in the next 3yr/36kmi, so I bet the additional lift of a 1 inch spacer above the coils would allow you to clear 30s, maybe 31s if you try harder... And undoubtedly make the truck look more rugged in the wild.
Have these thoughts crossed anyone else's minds?
  • Like
Reactions: JJC
ZipperKid
ZipperKid
Central Florida
Chevy S10
Here we go.
I've Got a rig with 33's and you Know Im gonna find how far you would need to go to fit them. Realistically though, I'm sure there's a limit for the fwd platform, but darn it we need the answer!
Old Ranchero
CO
no, just no.
ZipperKid
ZipperKid
Central Florida
Chevy S10
808Rider
Gee
Honolulu, Hawaii
4Runner
I've lifted my previous 2011 Tacoma. As popular as that truck is for off-roading and with the myriad of aftermarket suspension parts for it, you'd think a moderate lift 2" would be no problem. Wrong. The bearings in the front transaxles were at such an angle to cause premature wear and a constant grinding noise. I had to replace the bearings with an aftermarket modified bearing. Then the constant realignment adjustments and irregular wear pattern on tires. At $300+/tire, and the frequent time and visits to the alignment shop, I finally got very frustrated with it. Then had to bring back to stock for resale. Oh and then there was the ABS system that would kick in on mild turns because the yaw rate was different from stock.
So unless you're willing to have potential issues, wasted time for shop visits, extra money, especially for a new model, I'd say NO!
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis LS
The FX4 Comes with 29”. So I would imagine 30” would fit w/o any lift
Trying to lift a unibody, independent suspension truck might be tricky and expensive tho
Xtreme Thunder
NY
Honda, Toyota
Probably wouldn’t lift right away. FX4 and it’s tire package would provide enough clearance for my needs out of the box. Curious to see what aftermarket does in that regards. If I were to lift for some reason, it would be 1” or slightly less.
FirstOnRaceDay
Devin
Toledo Ohio
The real question is can it be lowered? 8.3” of ground clearance is too much for me. Drop it by 2”+ and it will be SICK!
HarrisonFordMaverick
Arizona
Subaru Outback
I really hope the aftermarket embraces this as an off-road/softroad platform. I’d be coming from a 1 1/2” lifted Subaru Outback on 29” tires. I personally don’t think I’d lift the Maverick unless it was a true SUSPENSION lift, not a spacer lift, that Rough Country (which is terrible btw just check the Bronco Sport forums) and the like sell. Those can lead to harsh ride, and bad cv axle angles if not done right. If someone offers an extended spring/dampener combo and a subframe drop to correct the driveline angles then I’d bite.
theek
Michael
Ottawa Canada
Honda CR-V, Subaru CrossTrek
How did you like the lift in the Subaru? What was in the kit?
Arizona
Subaru Outback
1” inch ADF spacer lift with half inch overload springs from rallitek. Built a 2” rear subframe drop to accommodate the 2” taller tires and the 1.5” lift. I only did the 1” part of the lift because I got I second hand for $40. It’s nice to have the extra clearance, but it transfers way too much road vibration into the cabin.
