Any Suspension Lift Kits?
R2theL
Raul
El Paso TX
Ford Maverick XLT FX4
I am about to get a 23 maverick tremor for off roading but i want to add a lift on it but all i see are 2inch body lifts is there any suspension lift kits? Ive always heard get a suspension lift rather than a body for off roading. Does anyone know where they would sell them because rough countrys suspension lift dosent fit the tremor.
mavmack
AZ
2024 Lariat Tremor
I've done exhaustive research regarding a lift for my 2024 Lariat Tremor.
I'm most likely going this route:
https://eibach.com/product/E30-35-057-01-22?epsid=3500
I've had Eibach's on many vehicles over the past 20+ years. Never had any issues - especially since they've been around for so many years.
Edit: With these springs and 245/70/17 tires, it should yield close to, or around ~11" of ground clearance for my Tremor. (y)
  • Like
Reactions: CLU
710-oil-614
Cal
2025 Hybrid AWD Lariat
Flat out suspensions would be my choice
710-oil-614
Cal
Sure, if you want to spend $3,500+ vs $400.
Might want to try apples to apples.
GR-40 would be overkill especially if you're comparing it some Eibach springs reusing the existing shocks but I'm getting you're after the look and not improved travel, ride, or quality.
mavmack
AZ
2024 Lariat Tremor
Correct. I am perfectly fine with the ride as is. Even if I got the Eibach springs.
If I wanted a full suspension, overkill setup, I would most definitely not be putting it in a Maverick.
And I get it - everyone's application is different.
