1/4 Mile 93 vs 87 Lobo
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
2025 Lobo, costco gas
Dragy verified, same road, same temp, weeks apart
87 - 14.62 @ 92.21
93 - 14.71 @ 93.02
Mpg is pretty much the same as well, premium vs regular.
I have been wondering what my LOBO would do in the quarter. Considering the LOBO weighs in at around 3731 pounds mid 14's is really good. Thanks for posting.
MosesP
San Antonio
Lobo
KsuMax
St Petersburg
2024 XLT Tremor
Updated original post. I'll try to get a better launch with the 93 octane and oil change is a few weeks.
Yes, seeing that now. I'll probably still run 93 in the summer and 87 in the winter.
3,890
Oh my bad. I meant the 60ft times
Op,
You didn’t try real gas.
Like 93 octane ethanol free !
rlhdweman
Random Lake Wisconsin
Thanks what year is Your Maverick? I know on Zeroto60 times they show the AWD 2.0 EB Mavericks from 14.5 -15.1 in the 1/4 mile.
2022 XLT FWD.
Buggy Man
Summerfield Fl
3,890
Curb weight 3686 for the base AWD EB 2.0 Lobo
I will for a run. Probably,
Oh yeah, before you time it run a few tanks of real gas through it so the puter’ gets used to the high. :’p
You did do that for the previous test right ?
rlhdweman
Usually run it at the end of the tank, gives it about 300 miles to adjust
Doesn't take that long, once the octane change has made it through the loop of fuel lines, the engine has adjusted. I notice the change in throttle response within 2 miles when changing fuel types.
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
Yup,premium is a waste of money with our maverick. I tow a 3100 lb boat.its not needed.
In my opinion unless I'm racing someone, whatever small improvement in performance of premium vs regular is not 70-80 cents/gallon worth of improvement. Unless my vehicle is pinging when using 87 octane, or it says premium fuel REQUIRED, it's getting 87. Even then I'll probably TRY mid grade first. 😅
rlhdweman
Were You guys using Sport Mode at the Track and on the Draggy Runs?
I was. I tried sport, tow & haul & normal modes, sport was the quickest.
