Steeda-Sergio
Diamond Sponsor
Sergio
Valdosta, Ga
2025 XLT Maverick (hopefully Soon) 2016 Grand Cherokee, 2022 Suzuki GSXS 1000 GT
Hey everyone,
I want to introduce to y’all our newest Maverick part, the Steeda Maverick Competition Strut Tower Brace!
We built this brace specifically for the 2022-2026 Maverick (XL, XLT, Lariat, Lobo, and Tremor) to tie the front strut towers together and deliver a more planted, confident front end. If you push your truck through on-ramps, autocross courses, or back roads, this brace sharpens steering response and gives you more precise turn-in and better feedback through the wheel.
Its double bar design uses two parallel bars joined by cross supports and a center plate, so it resists twisting better than a single-tube brace. It’s also built with the clearance needed for adjustable front struts, so it works with your suspension setup as your build grows.
Product Benefits
  • Double bar design for maximum rigidity
  • Gusseted strut tower plates that spread load evenly across the mounting area
  • Reduced chassis flex, sharper steering response, improved handling and cornering
  • Clearance for adjustable front struts
  • Gloss black powder coat with a Steeda logo cutout in the center plate
  • Mounting hardware included
  • Made in the USA
Get yours today at Steeda 555-5739 Maverick Competition Strut Tower Brace (22-26)
VIDEO:
PHOTOS:
Ford Maverick New Release ! Steeda Maverick Competition Strut Tower Brace STA03347__01047.1791560255
Ford Maverick New Release ! Steeda Maverick Competition Strut Tower Brace STA03344__69664.1791560255
BrandenD87
Branden
Kentucky
2025 Ford Maverick LOBO
I’ve come to realize that I need to just quit buying stuff for my lobo and instead wait for steeda to eventually come out with all the cool stuff. This is way cooler than my Massive strut bar.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I may have to get one and replace the Single-bar (first edition) that I had installed.
It appears to "Clear" the battery. I removed the Single-bar I had to replace my AGM... :unsure:
Jerry
SilverBullet2.0
Josh
2025 Ford Maverick Lobo
Do you notice a significant difference with the strut tower bar? My research is 50/50 currently. Since it seems like you also do Autocross maybe your opinion could sway me instead of just under hood eye candy.
BrandenD87
Branden
Kentucky
To be honest, I have no clue. I did the strut bar and all other suspension mods at the same time. I have no idea if it actually helped or not. But since I cut my shock towers for my adjustable camber plates, it does at least make me feel a little better having more metal bolted around the holes.
(forgot I even had the strut bar when I set everything out prior to install)
Ford Maverick New Release ! Steeda Maverick Competition Strut Tower Brace IMG_6393
SilverBullet2.0
Josh
Oh dang! OK yeah. You got a lot more goin on than just lowering springs and strut tower bar. Nice work!
FORZDA1
Fred
Gloucester, Virginia USA
2026 Maverick Lariat Hybrid
Hey everyone,
We built this brace specifically for the 2022-2026 Maverick (XL, XLT, Lariat, Lobo, and Tremor) ……..
Does it fit the Lariat hybrid?
Cancunbadlands
Cancun
Cancun
The Lobo utilizes stiffer upper strut mounts and steering rack bushings borrowed directly from the Mustang Mach-E.
Marty
2026 Ford Maverick Tremor
I cannot imagine ever pushing my Tremor so hard that I’d notice any benefit from that brace.
But it does look C A F !
If I did have the old style I’d have to upgrade on looks alone.
Desurface
Al
NY
25 xlt awd hybrid
Will this fit the hybrid? I have the single bar now and it’s really close to the lines thru the firewall.
Tbone289
The Ford Maverick Lobo utilizes stiffer upper strut mounts and steering rack bushings borrowed directly from the Mustang Mach-E.
I wonder how much improvement this brace adds to the Lobo
Stiffer strut mounts don't reduce strut tower flex relative to each other and to the chassis as a strut brace does.
tj@steeda
Diamond Sponsor
Timothy
Pompano Beach, FL
2019 Mustang GT - White Carbon Edition
Let me see if we can get confirmation on the Hybrid - I know we are still knocking out some trim levels.
Best,
TJ
tj@steeda
Diamond Sponsor
Timothy
Pompano Beach, FL
They should have a trade in program for those of us with the original model
I hear you, John — we’re constantly testing and pushing for improvements. Plenty of times the first part we make is the last part, but this time we discovered we could take it even further.
TJ
