Wind buffeting with all 4 windows down - solution?
Mavidiesel
New England
2022 Ford Maverick XLT 2.0 Ecoboost AWD
I noticed my Maverick’s got some serious wind buffeting (helicopter, eardrum sucking sound) going on with all four windows down. On most vehicles I’ve owned that only happens when just the rears are down but on this rig it happens when any windows are down. Does anyone know if window deflectors solve this issue for Mavericks? I don’t have the sliding rear window but I also wonder if those that do don’t have this issue?
dalola
Retired
SE Ohio 🇺🇸
Nope, rear slider eliminates buffeting. You could add a rear slider, or experiment with different windows at different heights, sometimes that helps.
Never had deflectors, so can't answer that one.
SkeeterB
The Woodlands, TX
I have the rear window and when opened buffeting stops. Middle rear seatbelt flaps and creates a lot of noise.
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
this is my experience too, opening the slider seems to quiet the wind buffeting.
Mavidiesel
Mavidiesel
New England
Any idea how much it cost to get one of those? Is that an available aftermarket mod?
dalola
Retired
SE Ohio 🇺🇸
Can't say for sure on a Mav aftermarket slider, I bet there is. Pretty common for most trucks. A little research should quickly yield results. You could also retrofit an OEM manual slider, but at higher cost.
baaron
SE PA
Maverick XLT Lux Hybrid
For the curious, the power sliding window is part number NZ6Z-6042006-G, the manual sliding window is NZ6Z-6042006-F.
From Ford, the power window is going for $1,057.23, the manual window is $1,006.17. Given the similarity in pricing, I'm assuming the power window only includes the window assembly glass and does not include the motor or wiring.
DesertSweat
Arizona
Ford Maverick Lariat, Honda HR-V 6spd
I would say the solution is to get a rear window. It's not cheap, but it will do the trick.
