Will take offs with Ford TPMS sensors be compatible?
TopGun22
TopGun
Ontario
SONATA GL Sport
Looking at set of complete Tarus take offs, with the installed sensors work on a maverick?
JP4AZ
Phoenix
Not sure if the Tarus have the same lug pattern. I think any 315 mh tpm's will work (not sure on that one either)
They do not show to be compatable. And therefore at the very least would require a programing tool not just the activation tool. I don't know but being an older design I would doubt that it has all the same functions that the preprogrammed newer model does. (Save $$ buy new ones the ones on the wheels are how old and the batteries only last 8-10 years or 100k miles).Maybe temperature, maybe revolutions per minute, maybe ? I understand new ones tested and ready to go(might already used somewhere) will be mounted on inside of tire and among other things will report tread wear.
Hillbilly
E. TN.
22 XL
Just have your original ones swapped in. That's what I did when I put on aftermarket rims
Ford Maverick Will take offs with Ford TPMS sensors be compatible? 20221011_094749
Thanks @MakinDoForNow
Can you suggest what to get for new ones ?
Not really, I usually buy tires at Discount and have them replace all sensors when I buy tires after 100k miles. They use their choice. May consider dealer since sensors are getting so damn integrated with make model and year of vehicles. I am 80 now and expect other than tires to just use dealer. On my lariat maverick at 15k miles my Michelin primacy have 7/32" left of original 8.5/32" so they are pretty much on track for the 65k warranty at 2/32". I normally replace at 4/32" or whenever I experience hydroplaning. No flack from discount, at least in past, getting milage adjustment for unused treadwear with having their certificates. Ford dealer did tell me at my oil change that they honored tire makers rebate and also would do free alignment on new set of 4 though I did not ask if that was standard or only a current "special"?
TopGun22
TopGun
Ontario
SONATA GL Sport
OK, would all new Ford tpms be the same ?
Ford Maverick Will take offs with Ford TPMS sensors be compatible? Screenshot_20230521-165634
AF Blue
US
NA
Have you tried TireRack?
Search the part: F2GZ-1A189-A
You will find plenty of options .. pick whomever you feel compfy with.
Surprisingly, same/similar sensors are 2x the cost at DiscountTire.
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
I myself got a whole new set of 4 off Amazon under $40 for my summer wheels/tires so I can use my OEM wheels/tires for the winter. Many options ifs you google the part#’s
