Widest tires?
KenJ45
2022 Ford Maverick XLT 2.0L Ecoboost
Has anyone looked into what is the widest tires you can put on stock XLT rims that won't cause any rubbing issues while turning?
Edit: I see in the pinned thread that 245/65R17 would fit, but wouldn't that increase the circumference making the speedometer slightly wrong? Would 245/60R17 also work and also be more accurate in circumference?
Edit 2: Ok, I see doing a search that 245/60R17 seems very limited in choices while 245/65R17 returns a lot of options... And I did some calculations and apparently it's only like a 4% difference in the speedometer reading. So... Basically I've answered my own question and probably didn't need to post this, lol. Sorry!! šŸ˜…
TOPGUNMAVERICK
JEREMY
XENIA OHIO
2022 MAVERICK- XLT WITH LUX AND 4K TOWING
I WAS THINKING BFG KO2- 245/65/17 ON MY FX4 FACTORY WHEELS. DO NOT KNOW IF HAVE TO DO LEVEL OR NOT. PRICE IS GOOD AT DEALER. ONLY $203.00 FOR RISED WHITE LETTER. WHAT SIZE MOST CAN DO ON FACTORY STUFF WITH OUT PROBLEMS RUBBING
KenJ45
KenJ45
I think that's a really good choice for tire size and brand. I might do that when it comes time to change my tires.
Maverickman74
Shane
Maui HI
I have heard the 245/70s are fine stock. Plus it gives you almost an inch of total ground clearance. I am gonna do a 2" lift aswell though. That will give me just under 1/4 inch less minimum ground clearance than a Sasquatch Bronco, which I intended to buy initially.
After those wear out I will maybe look into a pinch weld trim to fit a 265/70r17. That would be killer especially if I can maintain 20mpg.
Nw_adventure
Salt Lake city
Silly question- So to confirm the black wheels that come with the FX4 package ship with 225/65 rubber ?
Maverickman74
Shane
Maui HI
bgn
WA
KO2s are overkill for this vehicle and are significantly heavier than similar options. Like a lot.
I run 245/65R17 Toyos.
KenJ45
KenJ45
bgn
WA
@Naranjita has those and I believe he likes them quite a bit!
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
It'll probably look pretty awesome. The Maverick is not exactly an off-roading machine though, so it might be overkill, but it'll look good, lol.
Yes I do! They look amazing and perform beautifully on road too!!!
spexmaverick
Roy
California, USA
2023 Hybrid XLT Maverick
20MPG? That’s all you expect? If that’s the case, you’ll be fine with 245/65-17s. I have Falken Wildpeak ATs and my average is around 24-25MPG. With heavy winds, uphill driving or just plain got my foot into it, It’ll drop to about 22. Under ideal conditions I’ll occasionally get 29 to 30mpg.
Maverickman74
Shane
Maui HI
I have never had a vehicle do better than 21mpg and several have been single digit. These days Im in the low teens. After my factory 235 Falkens wear out I will be trying to find a set of Mud terrains that fit. A/Ts just dont give me any confidence offroad. There isnt a all terrain tire in the world that cant get stuck in soft wet grass on a sloped yard. The entire island I live on is a mountain. Nothing is flat that isnt paved. Typically mud terrains will take MPGs down another 1-2 over A/Ts. Maui isnt really built for good fuel mileage so keeping an average over 20 will basically make me a wealthy man.
