when do trailer brakes activate?
dochawk
doc
Las Vegas
I have a 2025 lariat hybrid with 4k towing.
When does it tell the trailer brakes to activate? When the brake pedal is touched, or when it pushes far enough to activate the actual brakes instead of regenerative breaking?
Ryom
PA
Diving in the manuals...
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=usa&buildtype=web
Your vehicle's brake system and the trailer brake system work independently of each other. Changing the gain setting on the controller does not affect the operation of your vehicle's brakes whether you attach a trailer or not.
https://www.vdm.ford.com/content/da...f/2025_Ford_Maverick_Towing_Info_fnl-Dec5.pdf
...the optional Integrated Trailer Brake Controller (TBC) assists in smooth and effective trailer braking by powering the trailer’s electric or electric-over-hydraulic brakes with proportional output based on the towing vehicle’s brake pressure...
It should start braking as soon as you press the brake any amount. Otherwise you'd always be getting pushed by the trailer while in regen. It'd be safe to assume that if your vehicle brake lights come on, the TBC is sending a signal to brake.
Mavster Mechanic
Hybrid
I have an aftermarket brake controller.
The trailer brakes come on any time the brake lamps are on (by design).
There is a G sensor in the box. The trailer brakes get stronger in proportion to how much you are slowing.
Very very likely the stock works the same way.
dochawk
dochawk
doc
Las Vegas
so if it is applying the trailer brakes immediately, wasting my kinetic energy, perhaps I should use L instead when I have the time and traffic clearance.?
Johnkn
MD
No need to overthink it.
The trailer brake controller is adjustable for trailer brake performance and load. Adjust it to your desired performance. You do not want the trailer to out brake the towing vehicle, you want some smallish degree of trailer push or bias against the tow vehicle.
good luck
Mavster Mechanic
Hybrid
I wouldn't use L.
L will rev your engine every time.
It won't burn gas but who likes spinning their engine 3500 to 4200 RPM on nothing but air if it's not necessary?
For me Tow/Haul is ideal going uphill and when going up on-ramps.
Normal or Tow is fine on flat and while cruising.
Eco is my go to mode in stop n go conditions with a trailer. Eco = double the regen without the engine spin-up.
Tow/Haul will also do the engine spin-up more often and won't allow you to EV drive. There's no reason to not EV drive with a trailer in stop n go or parking lot conditions.
dochawk
dochawk
doc
Las Vegas
In my ideal (and naive!) thought, I'd like the trailer physical brake to come on at the same time as the physical brake on the maverick. So if I can regen to a stop, great, and if I can't, so be it.
I'm not hearing it do that when I tap it without the trailer; just the electric whine. (I'm also not doing it at freeway speeds, if that matters.
I'm seeing it go on electric some of the time in tow/haul. Not a lot, but enough to have done the double-take a couple of times.
Mavster Mechanic
Hybrid
Tow haul shuts off the engine at stops. As does every mode. Sport too.
Kenv24
Ken
2024 XLT
good luck
And again, the trailer brake can be used JUST on the trailer by squeezing the two pieces together. That applies brakes to only the trailer if you don't have your foot on the truck brake. Usually used to calm a bit of sway on a travel trailer when it gets to wobblin'
Maverick2022XL
name
hinterlands
Someone needs to state the obvious, first and foremost it will only activate if you have a trailer with electric brakes on it. It activates when you hit the brake pedal period. The 2 issues you will have with continuous towing with a hybrid is working that hybrid battery harder than it otherwise would be. The jury is still out but continuous towing should shorten the lifespan of the battery. Because of the regenerative breaking you'll probably wear out your brake pads quicker decelerating with heavy tow loads than with a non hybrid.
Mavster Mechanic
Hybrid
[QUOTE="Maverick2022XL, post: 1324936, member: ] The 2 issues you will have with continuous towing with a hybrid is working that hybrid battery harder than it otherwise would be. The jury is still out but continuous towing should shorten the lifespan of the battery. Because of the regenerative breaking you'll probably wear out your brake pads quicker decelerating with heavy tow loads than with a non hybrid.
[/QUOTE]
No.
The jury came back with a verdict. You have it wrong. On two counts.
I actually have a 2022 hybrid. And a Brake Controller. And I ROUTINELY tow 3000 lbs. More than 10,000 miles and counting.
In Tow/Haul mode it uses the battery pack LESS than in any other mode. It saves the battery at a high level of charge for emergency or evasive maneuvers. It does not use the pack as much for MPG gains.
The truck boosts RPM at all speeds, like driving in a lower gear instead of using battery for boost.
Regenerative braking works the same; or a tad bit MORE when towing which means LESS wear and tear on your friction brakes.
For 3000 lbs and under; the hybrid variant is more well suited for towing than the EcoBoost. Really. No joke.
The transmission and braking is perfect for trailering.
Maverick2022XL
name
hinterlands
No.
[/QUOTE]
And the magic question are towing with a trailer that has electronic brakes on it? They all have brake controllers for regenerative braking. They also serve as a trailer braking system when you have the 4 and/or 8 pin trailer hitch connector. I'll circle back to the battery usage later but on regenerative braking if Ford designed it properly the trailer brake controller for a hybrid will have different braking strategy than a non hybrid. How it handles regenerative braking should work in tandem not independent of the abs, traction stability control and drive mode. If anything the abs/traction stability control should limit the regenerative braking to keep the trailer from jack knifing. Usually on EV's they limit or disable regenerative braking when towing. With that said towing will grind down brakes quicker than non towing. My mistake regenerative braking actually requires less friction not more so yes you should reduce the lifespan of those brakes at the same rate as a non hybrid towing because of less to no regenerative braking. Back to battery charge, if it is holding a high enough charge it will not activate the regen either which means more wear on the brakes. It has to use it less or you'll overheat the battery if the thermal regulation fails.
Also one has to keep in mind determining the GCVR for the braking strategy is going to differ depending if you are using the 4 pin (non electric trailer brake) vs. 8 pin. If you follow state law's for trailering in most cases the minimum GTW that requires an electric brake is 3000lbs.
Escapologist
Niagara Region, ON
Just thinking that for a travel trailer, where you've got a partially discharged house battery and maybe you are also running the fridge while travelling, the 12V load will be quite high. So then you are bleeding HV battery charge through the convertor, so it may not have a lot available for EV running.
Worst case scenario I think would be just after sundown, when your truck and camper got heatsoaked, 35C, so your truck AC and camper fridge are going like the clappers, AND you've gotta light the tail and clearance lights.
Kenv24
Ken
2024 XLT
No.
[/QUOTE]
Just because you have something plugged into the eight pin doesn’t mean the trailer has electric brakes. Some boat trailers don’t. My 7000 pound wakeboard boat behind my 250 uses the 8-pin but it’s a surge system…. no electric brakes on that trailer. My tandem 12 foot UTV trailer with the 8-pin has brakes.
Mavster Mechanic
Hybrid
It's either a new feature or everyone talking about "8-pin" connectors don't know what they are talking about.
Also the arm-chair worry worts don't know:
Pulling a trailer with the hybrid is very easy, and remarkably normal.
Any modern RV has low wattage appliances and an electronic coach battery charger. Safe. Efficient. Easy.
The electrical loads on the Maverick are low. But heck, the limit is the connector, the wires, and the fuse. The RV load on the Maverick is 10% of what the DC/DC converter is capable of.
Fact. No guessing here.
