What's that tag hanging from the mirror?
ExpoGuy
Los Angeles
Toyota Tacoma 2003
I was watching a Ben Hardy YT video about the Maverick Tremor. Hanging from the mirror is a tag saying avoid rear end collisions.
But I can't read the smaller print. Anyone know what it says?
You can see it at 4:10 on the video.
CNJFF
NJ
"R.E.D. Alert pulses your third brake light to reduce chances of being hit from behind by 50%."
Then it talks about insurance stuff. 5 years of coverage, $5k if you get hit from behind, $1k deductible reimbursement...
Apparently just a small flasher that gets installed to the third brake light. I assume they are charging you quite a bit for it.
Cancunbadlands
Cancun
Cancun
Just a small flasher into the third brake light.
ExpoGuy
Los Angeles
Toyota Tacoma 2003
Ok, now I know, thanks.
I remember reading about Mavericks being totaled with a rear end hit.
Is this light some thing new?
dmopro
Richardson, TX
If you are interested in a flashing third brake light, just replace the bulb with one of these. Just no insurance other than what you already carry.
As an FYI, the white one is cheaper (That is the one I put in). The lens cover is already red.
Red $12.95: Amazon.com: FANTELI 912 921 LED Bulb, Strobe Flashing 3rd Third Brake Center High Mount Stop Light, 300% Brighter Non-Polarity T15 906 904 902 W16W Brilliant Red : Automotive
White $9.97: Amazon.com: FANTELI 921 LED Bulb 6000K White, Strobe Flashing LED Reverse Lights, High Power 921 Bulb 21-SMD LEDs Error Free T15 912 922 906 W16W Backup Light (Upgraded, Pack of 2) : Automotive
I have also have Fanteli.
Plug and play.👍 $10-13 🤷‍♂️
When I bought mine, I was sent 2 in the box.
Ford Maverick What's that tag hanging from the mirror? 20250824_210323
6 sec. Video of it in action.👇
dmopro
Richardson, TX
KenR
KenR
DFW
F150
The flashing 3rd brake light is a dealership screw the customer $295 upgrade "that all cars & trucks get for your safety". Would you also like nitrogen added to the air in your tires? Standard air is only 78% but the special dealership air come in a bottled nitrogen and it's 81%. 😀
Ben6berry
Benjamin
Yakima, WA
2025 Ford Maverick Tremor, 2001 F150 Lariat, 2020 GMC Acadia, 2015 Caddy SRX
Says does not fit 2025 Ford Maverick
Ben6berry
Benjamin
Yakima, WA
I saw that too. I wonder if they just didn’t update their compatibility yet.
Could be. I would assume that it's the same one that they've used on the '22-'24's.
ryde4ever
Dennis
Indianapolis, IN
2024 Maverick XLT (Also, 2016 Civic)
It says it doesn't fit a 2024 either. I am going to give it a try since others have got it to work. Amazon returns are easy if needed.
Ben6berry
Benjamin
Yakima, WA
I think I might as well
So on that Fanteli - if you see that following car doesn't seem to be paying attention, can a quick release of brake pedal and repush cause another set of flashes?
Like it's on each engagement of brake light - no timeout until another request will cause it?
Glen - did you get the red or white showing in your video?
Thanks for that.
I'm guessing the T15 size is why it won't claim compatibility.
Unless the product changed - and it used to be a correct T21 before.
EXTERIOR BULB SPECIFICATION CHART
Lamp​
Specification​
Power (Watt)​
Rear lamp, brake lamp, rear turn signal lamp and rear side marker lamp. Low series.​
WT21-7W 26.5/8.5
Rear lamp, brake lamp, and turn signal lamp. High series.​
WT21-7W 26.5/8.5
