What's that tag hanging from the mirror?
dmopro
Richardson, TX
So on that Fanteli - if you see that following car doesn't seem to be paying attention, can a quick release of brake pedal and repush cause another set of flashes?
Like it's on each engagement of brake light - no timeout until another request will cause it?
Glen - did you get the red or white showing in your video?
Thanks for that.
I'm guessing the T15 size is why it won't claim compatibility.
Unless the product changed - and it used to be a correct T21 before.
EXTERIOR BULB SPECIFICATION CHART
Lamp​
Specification​
Power (Watt)​
Rear lamp, brake lamp, rear turn signal lamp and rear side marker lamp. Low series.​
WT21-7W 26.5/8.5
Rear lamp, brake lamp, and turn signal lamp. High series.​
WT21-7W 26.5/8.5
Push brake, 4 flashes. Release and press brake again, 4 more flashed. Rinse and repeat until you get the idiots attention.
