WeatherTech hood deflector installed
Clarkdonbran
I ordered the Lund deflector from the accessories site back in March, but it got lost in transit. The WeatherTech deflector seemed like a decent replacement. I just finished installing it.
Ford Maverick WeatherTech hood deflector installed 4B60C3FB-00A4-4572-8E87-42768330419E
Ford Maverick WeatherTech hood deflector installed 9A1FCB7D-BCB0-4885-A2DD-7F5954630944
Ford Maverick WeatherTech hood deflector installed ABB6408A-58B6-458D-9C2F-779ECC054BDC
Ford Maverick WeatherTech hood deflector installed 9492C60F-E51C-4EF9-9286-745AD7170109
FriscoTXJoe
2022 Maverick Lariat
I'm kicking this idea around while waiting for the dealership to have my truck ready.
What are the main benefits? Prevent rock chipping on the hood?
Does it create hood shake at high speeds?
Is there an adhesive to mount this? Wondering if that would be a problem for car washes or when you remove it?
Clarkdonbran
Clarkdonbran
I like the looks and I’ve had some rock issues lately. I think it mostly protects the leading edge of the hood. I haven’t driven with it installed yet. It adheres with 3m tape. Feels pretty sturdy.
sn00pyguy
Sn00pyguy
Elyria, OH
2020 Outback
I would get it to prevent the chipping. It will also prevent bug guts at least on the hood front. I order one from RealTruck.com. The install uses plugs that already exist that hold the foam insulator in place at the front under the hood. There are also some clear rubber feet to use so the wind doesn't bounce the shield off the hood. It does take extra time for the paint to totally cure. 60-90 days? And I am not sure if the chipping was from paved roads or Dirt road drivers. That would be good to know.
FriscoTXJoe
rclee
Rob
Dayton Ohio
Last Truck Ever
2023 Hybrid Maverick XLT
Is no one concerned about the 3m tape directly on the paint? I've used the 3m tape in multiple applications, and over time it's just ungodly trying to remove it. Since you can count on these deflectors to wear out / need replacement after several years, I anticipate a helluva problem getting the old tape off, without damaging the paint. I'd rather have a bolt on option -- love Weathertech, but they don't seem to have one?
athertonbt
TN
2022 Maverick XL EB FWD Carb Gray
There's a build out there somewhere with the bolt on option that uses existing holes under the hood...just have to comb through the posts...
PDM33
Phil
NE Ohio
2022 Maverick Lariat Hybrid
That one looks really good! Very low profile, I like it. Too bad I already did my Graphene coating and nothing will stick now. That bolt on one would be my only option at this point.
Dad
Earlier on this thread someone mentioned a bolt on hood protector available from RealTruck.com. You might want to check that out.
Jah.
Jah.
Central Florida
Avs bugflector 2 from realtruck . bolts on with plastic grommets in existing holes .also covers the front fenders edges . I had to extend the center two flanges to match up with the holes . others didn't have this problem . like the product but not avs customer service . I was missing two grommets and had to buy from Amazon because avs never did send them after two contacts . also like that I can lean forward and see top edge of bugflector to tell approximately location of front of truck is when parking .
Ford Maverick WeatherTech hood deflector installed 20220509_141016
PriusHater
Michael
www.rocketstem.org
Looks like an exact match to the Ford OEM hood deflector. No surprise there as it is produced by Lund too.
Shakesbear
J. R.
Other than a lot of elbow grease, goo be gone, and WD40 (best for removing 3M tape), I've never experienced a problem removing 3M tape. It is damn sticky stuff though ;) Always treat the area with a little Mirror Shine afterwards.
BradGroux
Houston
msft.expert
2023 F-150 XLT Powerboost
Orange Goo Gone works wonders for the 3M tape residue.
