Weather Tech Mud Flaps?
Wrench77
New Hampshire
Cadillac ATS, Ford Maverick pre ordered
I see Weather Tech has mud flaps listed for the Maverick now. Does anyone have them on their truck yet? From what I can see from the install pictures they cover a lot more then the factory ones do. The price is great too at $100 for front and rear.
Timaysz
Southern Wi
Ford explorer sport trac
I was planning on getting the weathertech mud flaps... And weathertech floor mats... Which I need to order now mav started shipment last week
prsncat
1997 Ford F250HD 4x4
I ordered both for my 23 EB XLT AWD BAP Maverick. The mudflaps should arrive today. The floormats are scheduled to arrive Friday. I will post pictures to this thread when they arrive and when they are on or in the Maverick for you.
Wrench77
Wrench77
New Hampshire
It looks to me the big gap on the left rear wheel well is filled in nicely with these.
prsncat
If you get the Weathertech flaps, the first step is to install the protective paint film. Make sure you do this first. I decided I didn't like nor did I need the protective film after doing the first one. Thus, I removed the first one I installed and didn't install the others.
Close up of one of the front ones. First from the front.
Ford Maverick Weather Tech Mud Flaps? mudflap_front
Next, from the rear:
Ford Maverick Weather Tech Mud Flaps? mudflap_front2
Rear mudflap from the front.
Ford Maverick Weather Tech Mud Flaps? mudlfap_rear
Rear mudflap from the rear.
Ford Maverick Weather Tech Mud Flaps? mudflap_rear2
A view from a little bit further back so you can see both of them installed.
Ford Maverick Weather Tech Mud Flaps? mudflaps2
I have not decided if I like them or not. Yet, they do look "factory" and they were very simple to install.
Wrench77
Wrench77
New Hampshire
looks great thank you for the pictures.
bbhaag
Are these molded plastic? I'm assuming for the price they are but just asking.
NJBob
New Jersey
I put a set of the Weathertech mudflaps on today. The hardest part was to peel the protective film from its backing, its not cut out so great. Also used soap to get it positioned perfectly but did not stick so great. The next three did not use the soap technique no issues.. I think they fit and look great. I had the Ford ones on my build put took them off due to the constaints. Glad I did.
mikegs1952
mike
idaho
F150
Any drilling required?? Did you put any ppf on the area first?? Thanks and congrats
NJBob
New Jersey
No drilling you have to take out some push pins and replace them with a clip and screw provided. I did put the film on the car first. The film did stick out a bit from the mudflap when aligned to the wheelbwell opening. I can see why a previous poster left them out. But a very minor criticism.
hungliketictacs
Austin
Maverick EcoBoost FWD
I would love to know expected and tested mpg impact on installing mudflaps like these
mikegs1952
mike
idaho
F150
Better to see a little ppf sticking out than worrying about rust underneath the flaps.
prsncat
I didn't see a reply to your question. Yes, they are molded plastic.
I am the one that posted the pictures on the BAP EB above. They have grown on me and I have decided I am going to leave them on.
I am grateful someone chimed in about using the PPF. I should have mentioned that using soapy water doesn't work. Sorry about that! I used soapy water on the first one and regular water on the second one. Like the other poster, the regular water works better. I didn't like the look and took it off after 1 front and 1 rear. I am willing to go without the PPF on mine.
The floor protection will arrive sometime today.
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
These flaps look pretty nice, but the coverage is nowhere near as good as the RokBlokz in the back.
Sagara
Saskatoon, SK
2022 Ford Maverick XLT
For the front mudflaps did you put the felt liner back in place like factory, or in front of plastic trim like the installation instructions?
Just installed mine and noticed with the felt behind the plastic trim the gap is quite wide and a tad loose.
The PPF was a royal pain to get in place. Need to see in a few days to see if it will stick or need replacements.
Inner edges of the mudflaps are smooth so there's less chance of it rubbing the paint down.
