Water on passenger floor
CMFX4
Christian
Kia Forte Koup
Has anyone noticed a buildup of water on the passenger side near the door? I noticed it this morning after a heavy rain, my mat was soaked with water
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
This has happened a couple times. The insulation may be missing in the door.
check this thread
ffoc01
2022 Mav Hyb FE, 2014 Flex
Do you have a sunroof? Could be either a blocked drain tube or a drain tube disconnected from the track.
CMFX4
CMFX4
Christian
Kia Forte Koup
Nope no sunroof, taking it to the dealer first thing tomorrow, luckily I’m off and I have a heat gun to dry everything
Ford Motor Company
Official Ford Account
Dearborn, mi
Hey there! Could you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to get to the bottom of your Maverick's water issue for you!
CMFX4
CMFX4
Christian
Kia Forte Koup
Took it to Gary Yeomans Ford in Belleview FL and they said they couldn’t find a problem but they seemed rushed and annoyed I didn’t have an appointment. I’m really disappointed with this aggravation in my first brand new vehicle purchase
CMFX4
CMFX4
Christian
Kia Forte Koup
Used a heat gun and yet the floor is still mildly saturated now I’m concerned with mold
CMFX4
CMFX4
Christian
Kia Forte Koup
Update: the cowl under the hood was loose and not sealed properly, Mullinax ford to the rescue, the other dealership I took it to barely looked.
Johnkn
MD
A heat gun will never dry the carpet and pad. Lift up the front of the carpet and wedge something in to keep it raised (like a long funnel). Put a dehumidifier in the truck with the windows up and let it run for ~2 days. A small fan aimed at the spot will help wick the moisture as well. Good luck...
MORRISX5
Hagerstown
I had no heat in early December and we discovered my cabin filter was frozen. Water came in somewhere but it hasn't again.
CMFX4
CMFX4
Christian
Kia Forte Koup
Mullinax had it two days and dried it all out for me, I think it’s all good now luckily. Hopefully that’s the last issue for awhile 😂
Kjjohn
Karl
Folkston Georgia
I am also having the same
issue with my Maverick
013SamIAm
Samuel
Summerville,SC
2015 Flex, 1965 Ford Galaxie, 2014 Toyota Camry
Was just going to ask if the cowl seal was properly attached or if you have tree debris around it. You wouldn't believe how easy any car can get a little debris inside and then a huge leak. Always get rid of the pine needles and other things off the cowl. Once they go in and accumulate the can block it up and then leak inside.
Mimmoc10
Jeep Gladiator & Ford Maverick
I’m having the same issue. Is it confirmed the cowl seal is the issue?
