Useless Observation
Marty
2026 Ford Maverick Tremor
FWIW,
From new I kept an eye on my 12 volt battery in my 2024 Ecoboost.
From day one until Bambi murdered it 18 months and 20,000 miles later.
Resting voltage was always 12.4 VDC on my AGM
Now on my 2026 Ecoboost it’s 12.8 VDC
Did ford finally fix the state of charge issue ?
Mr Clarity
Charlottesville VA
2024 Ford Maverick Lariat FX4
FWIW,
Your heading was correct.
Red Eyes - Wide Shut
West
2024 XLT
Thanks, I couldn't have said it better. All things must pass.
smoreho2
Virginia
2023 XLT Hybrid (October 2023)
FWIW,
AGM battery installed
MaverickDragon
Grand Canyon, AZ
@Cherokee
Not at all useless observation.
12.8 on your AGM is very good, in the optimal range and especially compared with the 12.4 volts you were getting previously.
For those interested, I found this chart handy..
Cancunbadlands
Cancun
Cancun
AGM battery is the answer
Waterick
Laurens county SC
The EcoBoost has mostly come from the factory AGM equipped. There were some exceptions early on due to supply shortages. I think the stop/start system needed it.
Marty
@Cherokee
I like that Chart !
Knowledge is Power, :’P
Thank you Mr. Dragon.
FordPrefect
Rick
2025 Ford Maverick Lariat Hybrid
FWIW,
OK, I usually wouldn't post anything but my wife insisted on opening that second bottle of wine so here goes. Reading all the battery posts, I recently decided to check my battery on a rare three day park for my 2025 hybrid with a Oct 2025 build date, 8,400 miles.
Battery after a few hours 13.03
Next morning 12.94
Day 2 12.90
Day 3 12.87
Day 3 after waking it up 12.48
ice445
Ryan
Utah
24 XLT Tremor
Did you test with a meter? I’ve found interesting behavior with modern vehicles in that regard. Voltage at the posts is always higher than interior readouts, and if you disconnect the posts the voltage usually goes up quite a bit. So many vampires drawing power all the time.
The SoC value if you have a scan tool seems to get the closest to what it actually is.
My 24 came with an agm, but imo the only improvement ford has made in this regard is making the battery way easier to remove 😂 I removed mine to put it on a tender and recondition it and it’s just such ass compared to the redesign…
Marty
Did you test with a meter? I’ve found interesting behavior with modern vehicles in that regard. Voltage at the posts is,,,,,,,
Yes sir !
With my very high quality
$7.99 digital VOM
From Harbor Freight.
On the battery posts.
:’P
FWIW the same meter is at Wally World for
$12.95 but it comes in black. I have both.
They are exactly the same and test out exactly the same.
2022 pushed behind 2023's
mike
ca
maverick
2026 xl awd hybrid
5k now
I've seen 12.2 right after turning it off..
Ford has some terrible engineers at times.
Frequently seems to undercharge mine even if the ac is on.
I'll bet when you got your 1st truck with AGM - the battery had been sitting on the shelf for awhile.
So by the time you got it, and it's strategy of only charging up to (same 92% SOC as hybrid?) xx.x% - it was too far gone to get a full charge from the BMS.
Which I recall is all you got out of it even after days on external charger.
Or it happened to be a problem battery anyway, and was never going to take a full charge.
I'll bet the date code on new truck battery is much more recent to it actually being delivered.
So no - Ford didn't fix anything. You lucked out.
