Updated FordPass app
Eggflipper
Gene
Massachusetts
2024 XLT TERRAIN
Did the updated FordPass app. I think i preferred the distance til empty vs percent of gas tank. I’m sure I will adjust to the new reading.
Carlitos_92
I agree... I liked being able to just look at my phone and determine if I had enough gas to get to where I was planning to go.
Since both pieces of information are still "in the truck" it'd be nice if Ford gave users a simple toggle setting to choose which they want to view in the app...
Dad
Did you update through your phone or was this done automatically from the truck?
Carlitos_92
Can't speak for OP, but I assumed they meant the phone app software, which is updated independently of anything the truck has going on. My update was the iOS version, installed yesterday.
commadorebob
Mine still has mileage. Says "Range: 72 Miles" because I last bought gas on June 17.
Ford Maverick Updated FordPass app Screenshot_20240724_195222_FordPass
Gullzway
OK
1968 Ford Mustang Fastback
This is why I keep Auto Updates off on my phone. Fortunately, on Android, you can always delete the app and install a previous version.
Eggflipper
Gene
Massachusetts
2024 XLT TERRAIN
I know, first world problems. I updated on my phone. It just gives me something to b***h about.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Mine shows distance till empty.
sprcoop
AZ
2023 XL Hybrid, 66 Mustang Coupe, 2012 Focus DCT
FordPass updated 6/19 on my Android and still shows "Range". Maybe this is an IOS thing.
Any Android users showing "Percentage"?
DaVicar
Hendersonville NC
2023 Subaru Crosstrek Limited, 2023 Maverick Lariat hybrid, Alto Blue, BAP
If you have the app installed on your Apple watch, it will still show range, even if the iPhone app shows fuel status. At least, as of today....
Justin says...
Justin
NC
'22 Ranger XLT
The older version, like a few months ago, had way more information and although not perfect, it was better than this one.
Dad
You are correct. The phone app is usually done automatically unless one has auto update turned off, but the truck has auto updates as well which led to my question. Additionally, the auto truck updates can also be turned off. I was advised to do so to help resolve the deep sleep hybrid issue, but so far it hasn't made any difference that I can detect.
Eggflipper
Gene
Massachusetts
2024 XLT TERRAIN
Just noticed that. Thanks for the heads up.
That update option is using WiFi, and from testing, while it may turn on once overnight to check if there is an update, the system is turned off otherwise (meaning it'll drop off the wifi network quickly). Not a likely reason for draining battery.
And WiFi is a small power-drain even when it's on the edge of the wifi signal and has to turn the radio up in power to use it barely.
The ATT cell modem though for telematics - not sure how often that is checking in to pass on data the Ford app is using, but cellular network uses a tad more power when you have bad signal, or no signal and it's constantly searching for it. That's constantly connecting so you can do your remote start or lock/unlock thru the app, besides info given.
Got good ATT network in your normal areas, especially where parked?
In manual under Vehicle Software Updates:
VEHICLE SOFTWARE UPDATES
Connecting to a Wi-Fi Network
Select the settings option on the feature bar.
  1. Select Automatic Updates.
  1. Select System Wi-Fi.
  1. Switch System Wi-Fi on.
  1. Select Available Wi-Fi Networks.
  1. Select an available Wi-Fi network.
Note: Enter the network password to connect to a secure network.
Switching Automatic System Updates On
  1. Switch Automatic System Updates on.
The system is now set to check for and receive system updates when it is connected to a Wi-Fi network.
