Underbody shield fastener part number needed
jon72vega
Jon
Niles MI
2022 Maverick XL
Today I noticed the shield/splash guard under the driver side doors was hanging down.
I found there are at least 2 missing nuts.
Does anyone have a part number or the size of the nut I need?
Shield hanging down.
Ford Maverick Underbody shield fastener part number needed 53544452828_886a253238_c
Loose shield under driver door by jon72vega, on Flickr
Missing fasteners.
Ford Maverick Underbody shield fastener part number needed 53544703215_cf380121bf_c
Missing nut by jon72vega, on Flickr
Ford Maverick Underbody shield fastener part number needed 53543398787_23ca10f8da_c
This is what the nut looks like.
Ford Maverick Underbody shield fastener part number needed 53544451753_ca2b115430_c
The nut by jon72vega, on Flickr
Found this diagram, but could not find a part # for the nut.
Ford Maverick Underbody shield fastener part number needed 53544589039_406cf23876_c
shield nut by jon72vega, on Flickr
I Google searched for over 30 minutes and came up with nothing.
Any help in figuring out the correct part # would be appreciated.
papak
Los Angeles
2023 Lariat Hybrid, CP360, Tesla 3, 1973 914 2.0l
Most likely M6x1.0
Gpp
Gil
Sanford nc
2022 ford maverick
Take a good nut and bolt assembly out and match it up at a hardware store or auto parts store.Amazon has them also.
fossil
ernie
ohio
ksc83
Kevin
Georgia
23 Maverick Lariat
Where did you find the diagram for the under body shield? I just had a tire retread fly off a truck and I ran it over and the rear drivers side portion ripped off. Now I’m hearing all sorts of noises like something is loose and jiggling around. Going to need to replace that piece now. Just need the part number.
bgn
WA
This might be useful as a starting point:
https://parts.lakelandford.com/a/Fo...loor-Under-cover--splash-shields/MM22592.html
I'd suggest double checking with the parts diagram available at your local parts counter. The one above seems to be from the service manual and I don't think they have part numbers.
jon72vega
jon72vega
Jon
Niles MI
2022 Maverick XL
An update on getting more fasteners.
I purchased these on Amazon. Body Flanged Hex Nut
Had to drill out the hole to 11/64", (I expected I would have to enlarge the hole to make the fasteners work) and Bob's your uncle.
Ford Maverick Underbody shield fastener part number needed 53551345405_348b9d45ec_c
Retainer nut for splash shield by jon72vega, on Flickr
Ford Maverick Underbody shield fastener part number needed 53551096468_a81d16082e_c
patriotsfan9
United States
My truck came with 1 missing. I found the part number and verified it fits.
Screw And Spring Washer
Part Number: W702413S450B
It was $11.70 for a 4 pack on Ford Parts
Kim
I need the part number for the passenger side cover. I’ve tried looking everywhere and can’t find it or the correct term for it to search by.
BlueSpec1
Gene
Andy
Saint John, Canada
XLT FX4
Again, realizing this is an old post but in case someone else has the same problem...
I found a part number at Eastgate as posted above ... Which looked like the nut we were all looking for.
But, no diameter listed so hard to know for sure...
Searched that part on Amazon and ended up here (https://www.amazon.ca/gp/aw/d/B0H1DGTK66?psc=1&ref=ppx_pop_mob_b_asin_title)
Part number match, should be good... But, No.
As you can see way smaller diameter.
Wrong part # on Eastgate? Amazon seller wrong?
Either way I trust the zip ties I have on there more than these tiny little nuts!!
Ford Maverick Underbody shield fastener part number needed 1000007869
FYI... Couple of the part numbers above were not for the nut....
Here is what I found... After a lot of looking haha
https://www.eastgatefordpartscanada...21-ford-fender-liner-retainer-nut-w709729s442
Ford Maverick Underbody shield fastener part number needed 1000007870
Tbone289
Just add a thin "fender" washer to that...
