Unable to put Rear Seat down
OldGrayHare
Toyota Tacoma. C7 Corvette
Has any of you Maverick owners had your rear seat stuck and unable to put it down after using the storage area under the seat? If so, how were you able to put it down? Thanks
Ford Maverick Unable to put Rear Seat down 50F0AB65-EC1F-4D5C-9EC3-6322827A6AEC
dennish
Goodyear, AZ
Ford Maverick Hybrid Lariat :-)
Honestly not being wise - are you pulling on the release handles on bottom of seat to unlock and saying it is stuck upright?
Whitenight
Charlie
Center of the Universe
2022 Maverick Lariat, 2021 Bronco Sport Badlands
Did you pull on the straps to release the locks to lower it back down?
OldGrayHare
OldGrayHare
That's correct..... pulled on the release handles to raise the seat to the position you see in the picture. The problem is that even with one person on ether side pulling on the straps, the seat will not lower in the sitting position.
OldGrayHare
OldGrayHare
Yes... one person on either side pulling on the straps still would not lower the seat back down.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
This might seem like another dumb question, but Is there anything you've put under the seat that might be obstructing it from closing?
Tailender
Will
Poconos
Maybe you tried, but did you push the seat up more then pull the strap to put it down. Mine was tricky until I figured that out.
Zotman
Detroit suburbs
Lariat Lux Hybrid, Focus
I did than when viewing a display model before the official release. Didn't know it had to be pushed farther back to release it, so I slunk away in disgrace.
TedTX
Ted
San Antonio TX
Lift and hold strap rotate hand so palm is resting flat on seating surface. Keep strap tight and rotate seat just a little more to the seat back then push back down. Keep strap pulled entire movement.
I had exactly same experience with seat stuck for the first two days of ownership.
Do you want the tip on reseating the seat back to stay in place?
Gullzway
OK
1968 Ford Mustang Fastback
DON’T do that! Pulling the straps releases the seat. Just push the seat back down.
It also locks in the up position, and you have to pull the strap to release it to lower the seat.
