Twin Clutch or Single Clutch Rear Differential in Maverick?
ZipperKid
Central Florida
Chevy S10
Is anyone aware of what type of differential is under the Maverick? I am hoping that they are using the twin clutch unit that they use in the Bronco Sport Badlands, at least in the FX4. I believe that the more capable off-road spec should have this equipped.
Does Ford have any mention of these specifications?
dp4616
Daniel
Sunrise, FL
2011 Ford Ranger
Watch the video on the TFL discussion with the Ford guy. He mentioned at around 26 minutes, that the Maverick is similar to Badlands, but only a single clutch - not double like the Badlands.
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis LS
Is anone aware of what type of differential is under the Maverick? I am hoping that they are using the twin clutch unit that they use in the Bronco Sport Badlands, at least in the FX4. I believe that the more capable off-road spec should have this equipped.
I wish I could find what the BASE torque split is for the non dual clutch.
but the system can send out 100% of torque to front wheels and up to 70% to rear wheels.
now the dual clutch system can then send 100% of the 70% to one of the rear wheels for better grip.
the regular system still has to send “SOME” power to each wheel. No specification mentioned any where of how much. But I would guess close to 40/60 split.
ZipperKid
ZipperKid
Central Florida
Chevy S10
Thanks for the pointer. I wish that they had put the twin clutch in the FX4 as it is "supposed" to be the off-road package. I hope that I can find out more about this single clutch setup. When I briefly read about the bronco sport, they mentioned the base model was an open rear differential with brake-assisted traction control. If that is the case with the Maverick, then I will just hope that they chose a common ring carrier size so that I can get a limited slip differential...
I think I am getting ahead of myself, though, since I haven't made my first payment... and my truck is still at zero miles!
D K
Portland
Colorado, M3, Corvette
I hope its nothing like the Evoque or the Focus RS
docwatson
WA
Nissans
I wonder if you can just swap the rear end from a Bronco Sport with the dual clutch in?
I can't find a good source for the Bronco Sport's gear ratio. Maybe 3.8?
Maybe they are waiting to make a Maverick Timberline
ZipperKid
ZipperKid
Central Florida
Chevy S10
I believe I read that the BS Badlands is 3.81 like the 4K tow Maverick. The swap would probably involve wiring that the Mav doesnt have, since I'm guessing that the twin clutch is electronically controlled. I think the best course of action for a LSD would be an aftermarket option when it becomes available.
PCK
Phil
VW R32; Maverick Tremor
The Tremor version of the Maverick will have the twin/dual clutch rear axle of the BS Badlands.
