Tremor suspension specs
Salwans
Oregon
2010 Audi A4
There isn’t much detail on the Tremor suspension in the spec sheet.
The only information provided in the technical spec sheet about the Tremor front and rear suspension is that it’s an “off-road tuned suspension”.
For example:
how are Tremor’s dampers different from the “mono-tube hydraulic gas-pressurized dampers with hydraulic stop” found in the FX4 package?
Do they have a remote reservoir?
Do they have a larger diameter? Etc.
thanks in advance.to anyone with further info.
fossil
ernie
ohio
"unique off-road-tailored front and rear suspension" is Ford's line and they're sticking to it.
If it's unique beyond dimensional support for the 8/10ths inch lift is anyone's guess but
it's pretty clear that the spring rates are lower than other Mavericks witnessed by 300# less payload.
Remote reservoir, no.
My guess is the shock dampening is higher to offset the softer springs to prevent bottoming, at least for the down/compression stroke.
Salwans
Oregon
2010 Audi A4
Thanks @fossil for this info. Higher shock dampening would explain the stiffer on-road ride quality my ‘23 Tremor Mav has over my previous ‘22 non-FX4 AWD Mav. That ‘22 non-FX4 AWD suspension was admittedly more comfortable on-road and had noticeably better speed bump absorption,. That said the Tremor has its benefits in the off road application.
Maverickman74
Shane
Maui HI
All the specs at which shocks are measured, the Tremor is a step above. Dont really have anything more I should say.
Salwans
Oregon
2010 Audi A4
I take Ford’s word for it. Still would be interesting to know the geeky details about what makes the Tremor’s springs, shocks, etc better for off-road.
fossil
ernie
ohio
Wouldn't we all :cool:
Maverickman74
Shane
Maui HI
To my knowledge the development test data is owned by the company that developed them. Unfortunately since its not a direct to consumer company they dont show off that kind of stuff. I imagine keeping it in-house keeps competition on its toes.
cthulhu_rising
2023 Maverick XLT Tremor
I'm no expert, and this is an uneducated guess so please take it all with a grain of salt:
I'd assume we've got at least a few things in common with the Bronco Sport Badlands since the base chassis are almost the same and the specs in terms of upgrade over non-Badlands models are similar.
If the Tremor is remotely similar, then this write-up may be of interest. It's a deep dive into the Bronco Sport Badlands edition suspension.
https://www.autoblog.com/2021/06/03/ford-bronco-sport-suspension-deep-dive/
TheShark
That was always my understanding that the Tremor and BS Badlands shared the same components.
fossil
ernie
ohio
Ford made a big deal about the BSBL having a H.O.S.S. suspension setup.
I expect the Tremor is somewhat less, probably in the shock/strut.
FischAutoTechGarten
Peter
Yeah, we'd hear about Tremor having the HOSS setup too if it were equal... they wouldn't let that marketing gem go unpublisized...
Maverickman74
Shane
Maui HI
From what I do know I think they are actually quite similar, possibly even that the Tremor shocks are better for a heavier vehicle with a higher payload. I think the HOSS branding is Bronco specific. They wouldnt put it on anything but a Bronco. Plus I still think they are in the capacity scaling with Mavericks, they sell as many as they can build. How many Maverick specific ads have you seen, I havent seen one and I have see alot of Bronco Sport ads.
Rivers90
Ben
XLT Tremor, Miata
I would be more interested in knowing how the programming is different. With so many things being computer controlled it can totally change how something drives.
