Touch up paint and application advice here please
Shack Miller
Shack
WA
2025 Maverick XLT
I searched, honestly I did, but 25 pages was too much for me to plow through.
I just put my first small scratch on my oxford white maverick tailgate today backing into a hidden object. Scratch is maybe 1.5 inches and not real deep but it still hacks me off. I have some touch up paint on order for later tdoay. My question: any tips or tricks i should observe to get a nice finished application?
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
assuming it is very narrow you can sometimes just light use some rubbing compound and only you will ever know it was ever there. Applying paint to a very small and minor scratch usually ends up making it more obvious than before you touched it, you might do better to put a touch of it on a q-tip, and just go over it a couple times and see if that blends the paint in. It's also good to work with a magnifying glass so you can see exactly where you are applying it if you're using a very narrow artist brush. Doing a fix is like the old doctor's oath 'first, do no harm'.
MikeS1942
Windsor Ontario
24 Maverick Lariat
I used a product called Scratches Happen. Simple to use. Matching colors and clear coat come together.
Cancunbadlands
Cancun
Cancun
Is it Hot Pepper Red a special paint color? No touch up paint job needed so far
Ecorydr
2026 Maverick Lariat AWD
I have had good results using Langka paints. However, some metallics dont look good touched up with any using a brush. Just cant seem to get the finished application to blend well.
Been looking for a decent cheap airbrush for my metallic painted vehicles.
Tip: dont use the included paint brush with touchup paints.... get some of these (below). Have found they work extremely better in applying the correct amount of paint a little at a time (without the blob effect):
https://www.amazon.com/dp/B07V71Z8PT?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4&th=1
Shack Miller
Shack
WA
2025 Maverick XLT
thanks to all for the help. I secured the proper color from my dealer................... and immedlately ignored all of the info here and used the applicator brush. The color match is fine, but now I have to sand and buff down. Suggestions/tips for that task? I will go to auto store and get some 2000/ 3000 grit paper.
BK007
BK007
OH
:unsure::unsure: :unsure:
Shack Miller
Shack
WA
2025 Maverick XLT
yeah, its called impatience
BK007
BK007
OH
MikeS1942
Windsor Ontario
24 Maverick Lariat
Add thin multiple coats. Don't go heavy all at once.
Awesemann
Allan
Portland, Oregon
2002 PT Cruiser
I've used DrColorchip.com before works great. Maybe check them out
Traveling Man
Raymond
2022 Mavrick
On Utube very good info
